Previous in Forum: Differential Expansion is More in Steam Turbine   Next in Forum: HVAC Question
VRF Y-Joint Distance
08/15/2015 1:03 AM
why the distance between y-joint to elbow and from one y-joint to another y-joint in VRF system is kept more than 2.4m or more?
Pathfinder Tags: vrf
Re: VRF Y-joint distance
08/15/2015 1:21 AM
08/16/2015 2:39 AM
Helped me out! I was still stuck on Visual Flight Rules from talking about the drones, FAA, and pilots licenses. Guess if took the HVAC concentration instead of Mechatronics I would have learned this in college.
08/16/2015 3:23 AM
Stupid edit time. My dyslexia kicked in here with vrf = VFR. Doh!
Hobbies - CNC - New Member
Re: VRF Y-Joint Distance
08/18/2015 10:33 AM
Because it is the engineered design!?
08/08/2026 8:02 AM
2.4 M minimum distance helps maintain stable refrigerant flow reduce turbulence & pressure loss and provide enough straight pipe length around the "J Joint"/"Elbow" for proper distribution.
Always follow the manufacturer's installation manual.
Bhairavi Acharya (1); Iceberg86300 (2); lyn (1); Original_Macgyver (1)
