Honeycomb girder launching gantry is specially developed by ZZHZ for highway bridge construction. And as a patent product, below content you have to learn:
- The air current could pass through the
honeycomb holes, thus greatly reduce wind impact on the main girder, make it
quite stable;
- The honeycomb girder is welded plate by
plate, so it has a relatively lower demand on welding, even if there is a mistake
welding there (and we will not allow this mistake usually), the large welding
surface will not lose stability, so it is quite stable and reliable
- Its section is isosceles triangle which is
the most stable structure in all shapes;
- The honeycomb girder sections are connected
with high strength bolts for convenient transportation and assembly. And the
connecting parts are stiffened plates which will totally meet the demands of
design loads.
