Previous in Forum: Harmonic Issues With VFD, Capacitor Banks   Next in Forum: Installation of Transformer on Poles
One and Half Breaker Scheme Protection CTs
08/26/2015 6:20 AM
Hi i had a problem regarding the 380kv substation TEE protection CTs. We are using 6 CT method(of different cores) for Tee protection in one and half breaker scheme. My doubt is for which CT is specific for what protection and another 2 core CT were installed outside the GIS and what is significance of those 2 core CT.
Good Answers: 445
Re: One and Half Breaker Scheme Protection CTs
08/26/2015 10:07 AM
Probably for protection of the entire GIS installation. Unfortunately your description is too vague for an accurate response, a SLD might help to remove any doubts.
08/26/2015 2:01 PM
Did you read your manual? Did you ring your supplier?
Good moaning!
08/26/2015 4:49 PM
NEVER, EVER ask strangers to do your electrical design work for you.
You will surely kill someone with your lack of professionalism. Unfortunately, it probably won't be you.
Read this:
An electrical code is a set of regulations for electrical wiring. The intention of an electrical code is to provide standards to ensure electrical wiring systems that are safe and unlikely to produce either electric shock or fires. Ways in which electrical codes ensure safety include ways to prevent (or mitigate) short circuits, ground faults, and overheating from inadequate current-carrying capacity (ampacity). Appropriately rated fuses or circuit breakers are used to interrupt a circuit loop whose ampacity is exceeded to avoid overheating of wires or other fixtures. Electrical codes are usually devised by national or international technical organizations, and adopted as law to make them enforceable. Electrical codes differ based on geographic area. See the following:
Electrical Codes, Standards, Recommended Practices and ...
Register to Reply 3 comments
Crabtree (1); lyn (1); RAMConsult (1)
