Previous in Forum: New coin challenge   Next in Forum: T'Stats - Who you gonna call?
The physical limits of fiber optics
07/20/2007 7:17 PM
This is a question for anyone who knows about the physics of optics: What is the theoretical lower limit to the diameter of optical fiber? There are many biological molecules that form tube-like structures that are only nanometers in width. Microtubules, components of the eukaryotic cytoskeleton, have a diameter of ~ 24 nm. Could it be possible to pipe a beam of light down one of these structures? What is the relationship of wavelength to fiber diameter?
"When one man, for whatever reason, has the opportunity to lead an extraordinary life, he has no right to keep it to himself." -- Jacques-Yves Cousteau
Pathfinder Tags: fiber optics microtubules. optics
Re: The physical limits of fiber optics
07/22/2007 10:37 AM
I might assume that this is similar to that of a uWave wave guide.
The wider dimension has to exceed 1/2 wave length, so
for visible light, this works out to be 275nm.
Actually, its probably worse due to the fact that your biological tubes
are not good reflectors.
They are dielectric discontinuities / poor reflectors.
The angle of incidence for TIR to take place
limits what goes on in the tube, so
its probably a lot larger than 1/2 wave in width.
Single mode comm grade optical fiber is in the 60um area for 1.5u IR.
alzie
Good Answers: 109
07/22/2007 4:45 PM
Hi you are absolutely right.
Only in the infrared and visible it is preferred to take the circular waveguides.
These have 4µm diameter for the visible.
So with xrays there will be smaller diameters. (See SPIE.org for literature)
These diameters will enable longdistance waveguides (more than 100km without repeater in the IR).
Some electromagnetic radiation is leaking from smaller holes so light can be transmitted through holes of a few nanometer size but only very limited energy.
This is used in the optical nearfield microscope where optical lateral resolution can be much better than the wavelength.
RHABE
07/23/2007 5:21 AM
Do you have to reduce the wavelength by a factor n, the index of refraction?
08/13/2007 8:57 AM
The limiting wavelength to diameter ratio is; pie : 1 = 3.14... The wavelength can then be lower than the limit.
Register to Reply 4 comments
alzie (1); Anonymous Poster (1); dietmarG (1); RHABE (1)
You might be interested in: Fiber Optic Cables
