Previous in Forum: Steam Heater for Drum   Next in Forum: Thinning Rate
14 comments
Engineering Fields - Piping Design Engineering - New Member
Serrated Spiral
09/17/2015 11:38 PM
Dear All,
Is There any tools to measure serrated spiral groove on raised face flange?
Regards,
wito
Re: Serrated Spiral
09/17/2015 11:42 PM
Yes. Many.
Too many to list here.
Re: Serrated Spiral
09/18/2015 12:33 AM
GA. "Phonographic" is pretty catchy word though,grin.
The doctor said "just one post or reply aday in CR4, take it or leave it". I said, "what does that mean?"
Re: Serrated Spiral
09/18/2015 12:55 AM
hi gent,
thank you so much on your respond , would you like to show me a photo or a Brand from that tool?
regards,
wito
Good Answers: 21
Re: Serrated Spiral
09/22/2015 7:45 AM
Lynn is a very soft guy......Fedex the job through , and he'll do it for you!
Re: Serrated Spiral
09/18/2015 12:54 AM
"Flange finish is generally measured by visual and tactile means. Comparing the feel of the machined face with that of a surface finish comparator gauge, occasionally referred to as a Rupert gauge, is considered adequate.
There are two common methods of expressing roughness.
They are the Arithmetic Average Roughness Height (AARH) and the Root Mean Square (RMS) Average.
Arithmetic Average Roughness Height- Calculation of the Arithmetic Average Roughness Height involves measuring the distance of the peaks and valleys and performing an arithmetic average of the measurements.
Root Mean Square Average - Calculation of the Root Mean Square Average involves measuring the distance of peaks and valleys, adding the square of these measurements and calculating the square root of the total.
The RMS value is approximately 11% higher than the AARH value."
...or you can use a surface roughness tester.....here's one, the Mitutoyo xxx...
https://www.youtube.com/watch?v=AaK1xtUPIpE
https://www.youtube.com/watch?v=xOiZVy_ry0E
...ref link...
https://groups.google.com/forum/#!topic/materials-welding/NZFHZpgC4F8
Re: Serrated Spiral
09/18/2015 1:31 AM
Hi Eagle,
thank you so much on your explanation
regards,
wito
Good Answers: 34
Re: Serrated Spiral
09/18/2015 7:35 AM
Hi
Review ASME B16.5 and ASME B16.47
There are two common methods of expressing roughness. They are the Arithmetic Average Roughness Height (AARH) and the Root Mean Square (RMS) Average
WP
Good Answers: 137
Re: Serrated Spiral
09/18/2015 9:32 AM
Déjà vu?
Good Answers: 34
Re: Serrated Spiral
09/18/2015 10:11 AM
Au royaume des aveugles, les borgnes sont rois
Good Answers: 137
Re: Serrated Spiral
09/18/2015 11:49 AM
Oui, d'accord.
Re: Serrated Spiral
09/18/2015 12:15 PM
Il semble que nous utilisons le même moteur de recherche..
Good Answers: 34
Re: Serrated Spiral
09/19/2015 3:56 AM
Hi SE
Draußen gejucht, drinnen geflucht je
WP
Re: Serrated Spiral
09/18/2015 12:51 PM
Of course. First you need to determine what you want to measure.
Good moaning!
Re: Serrated Spiral
09/19/2015 9:00 AM
Here is a rednek method:(hic)
Place the flange on a turntable,gently apply the pickup arm,and listen carefully.
The conventional pickup arm is not recommended,so use a non-contact laser pickup,a pneumatic back-pressure sensor or a MEMS sensor.
Just whatever you have in your scrap bin.
If none of the above are available,use a paper clip,with the point cut to an angle of 22 1/2 degrees.
Send the output to a A/D converter.
Convert the digital value to decimal.
Do the same with a known flange.
Construct a right triangle using the values as one for side each.
Determine the value of the hypotenuse
The difference, is your difference.
See! That was easy!
OH Shi--.!I remember now!
I quit my job as a math professor last week.
Would you like to buy a set of encyclopaedia's?
Register to Reply 14 comments
Codemaster (2); Crabtree (1); Darwito (2); Hilton (1); HiTekRedNek (1); Legolaz (1); lyn (1); SolarEagle (2); Whitephone (3)
