We are designing a coolant supply system, here one common pump supplies
coolant to 5 machines there 5 machines are placed with in 10 mtrs .
each machine is of 2 mtrs in length each machine has to receive 60 ltrs
per minutes(LPM) supply will be the capacity of this pump.
01).Will the last machine ie,5 th m/c,(4th m/c,3rd m/c) receive 60 LPM of coolant supply or will the supply go down
b)if i have to maintain 60 LPM supply for the last m/c ie, at the
distance of 10 mtrs which type of coolant pump i am supplied to select.
C)Can any one suggest such pump avaiability in india /southindia/chennai.
Regards
