Previous in Forum: Ultrasonic Leak Detection   Next in Forum: Nothing new but bleaching earth.
18 comments
What is it??
09/21/2015 11:13 AM
only clue, you will NOT find them in a 7-11
Re: what is it??
09/21/2015 11:30 AM
Re: what is it??
09/21/2015 11:42 AM
wrong Kung fu throwing stars
Re: what is it??
09/21/2015 12:30 PM
It doesn't take a lot to figure out, espcially when you leave a big honkin' clue in the photo and in the image code:
http://cr4.globalspec.com/PostImages/201509/boeing-737-max-assembly-4_64A7C3F6-5056-8D7B-056A120B0579B9A5.jpg
Good Answers: 97
Re: what is it??
09/21/2015 11:48 AM
This is Detroit's version:
CRTL-Z
Re: what is it??
09/21/2015 11:51 AM
I bet that adds 5 MPG
Re: what is it??
09/21/2015 1:21 PM
Looks like the right answer has been given already.
Before I saw the pic, based on the hint I could see from the CR4 main page, I thought it was going to be an 8-12.
Re: what is it??
09/21/2015 1:42 PM
there ya go!
Re: what is it??
09/22/2015 1:10 AM
I thought these were made of graphene, freshly made and painted.
The doctor said "just one post or reply aday in CR4, take it or leave it". I said, "what does that mean?"
Good Answers: 97
Re: what is it??
09/21/2015 2:52 PM
I know that if the winglets on the Southwest 737 from Reno to Los Vegas had been of that type (Upper and Lower) the lower section port wing would have been ground off in the crosswinds that had cancelled the Reno air races that day. The wingtip came within inches of the runway. It made me wonder what effect crosswinds have on winglets.
CRTL-Z
Re: what is it??
09/21/2015 5:39 PM
It's jokingly referred to by Boeing engineers as the boomerang design.
Re: what is it??
09/21/2015 11:32 PM
"Thank you for flying Western Airlines. Ya all come back now"
Re: What is it??
09/22/2015 6:05 AM
I've read all the posts and still haven't a clue......
Re: What is it??
09/22/2015 7:34 AM
its a tip of a planes wing to reduce drag
Re: What is it??
09/22/2015 8:38 AM
Actually, they stop the high pressure air under the wing flowing to the low pressure above the wing around the wing tip in a kind of "short circuit", thereby producing more lift from a wing of the same length with them fitted compared to one that is not fitted. Wing tip vortices are eliminated, and the plane uses less fuel. Or, at least, that's what Fairfax and Carstairs told me.
Good moaning!
Re: What is it??
09/22/2015 10:07 AM
Thanks Fredski - I live and learn.
I had a feeling wing tips were turned up for some aeronautical reason.
Being told a while back that the reason wing tips were turned up was to enable aircraft to pass through narrow hangar doors was always a bit suspect
Good Answers: 123
Re: What is it??
09/22/2015 8:19 PM
I have seen the upswept winglets appear on many planes. While at the Boing tour I also saw the "improved" winglet design on the 787. What I find strange is the design used on the A320 series planes that extends above and below the wing end.
Bob
Re: What is it??
09/22/2015 8:43 PM
Look, if one fin is good, two have to be better.
Good Answers: 123
Re: What is it??
09/22/2015 9:41 PM
Unless you are in rush hour traffic in.....Finland.
Bob
Register to Reply 18 comments
bob c (2); Crabtree (1); Fredski (4); horace40 (2); Legolaz (1); lyn (2); Rixter (1); StandardsGuy (1); truth is not a compromise (1); Unredundant (2); Usbport (1)
