Previous in Forum: V5 Cell Failure in TMdrive-MVG   Next in Forum: Single Phase to Three Phase Supply (Domestic)
Medium Voltage Concentric Neutral Cables with Shield
09/21/2015 3:35 PM
If anybody can help me on how much should be the short circuit current rating of concentric neutral conductor compare to main phase conductor rating ?
Also what about the conducing shield short circuit current rating ?
Re: Medium Voltage concentric Neutral cables with shield
09/21/2015 3:57 PM
Google can.
Short Circuit Current Calculations
Simple Methods for Calculating Short Circuit Current Without
Or, NEC Code 409.
You really should learn how to do this yourself.
Good Answers: 42
Re: Medium Voltage Concentric Neutral Cables with Shield
09/21/2015 11:57 PM
Try these also:
Formula-Short Circuit Current for Copper Shields
http://www.generalcable.com/NR/rdonlyres/33CD44FA-5F8A-42B6-B12B-A05BAF12CAEC/0/Spec_F150.pdf
or:
ICEA-Publication P-45-482-1994 SHORT CIRCUIT CHARACTERISTICS OF METALLIC SHEATHS AND SHIELDS
and:
ICEA-Publication P-32-382-Short Circuit Characteristics of Insulated Cable
Julius
Good Answers: 42
09/22/2015 2:40 AM
It seems to me General Cable changed the address of this "formula". The old one was retrieving a pdf file like the attached.
I have to mention also, the ICEA Publication P-45-482 was revised and the last edition is from 2013-I think.
Julius
Good Answers: 42
09/22/2015 4:54 AM
In the following pdf there is a table in which is indicated approximate shield fault capacity.
http://www.generalcable.com/getmedia/4fa12d94-042f-4746-bbad-7c2f40b7833e/41988EmpowerLBrochure_LR
Julius
Register to Reply 4 comments
