Previous in Forum: Radioactivity in Pure Lead   Next in Forum: Corten Steel Best Way to Preserve Orange Rust Color
Engineering Fields - Piping Design Engineering - New Member
Different Primary and Secondary Clarifier Mechanism
10/01/2015 2:43 AM
What is different primary & secondary clarifier mechanism?
"Learning how to learn is life's most important skill."
Re: different primary & secondary CLARIFIER MECHANISM
10/01/2015 2:47 AM
Please clarify your question!
Your first reply to this would be the primary clarifier and your second post the secondary clarifier!
Mechanically this is clear as new engine oil!!
10/01/2015 3:42 AM
PRIMARY SOLIDS CONTACT CLARIFIER MECHANISM & SECONDARY SOLIDS CONTACT CLARIFIER MECHANISM BOTH ARE WHAT IS DIFFÉRENTS?
Register to Reply Off Topic (Score 8)
Hobbies - CNC - New Member
10/01/2015 9:27 AM
  1. First of all, STOP YELLING! All CAPS is the same as yelling!
  2. Second of all.... How about a complete question?
  3. What industry are you in? Water treatment? Waste water treatment?
  4. Phrase your words as a complete question!
  5. What do you want to know specifically?
Good luck!
10/02/2015 2:36 AM
One is primary and the other one is secondary. You might be able to see which one is which if you look at your process flow.
I would not put the secondary before the primary unless you know exactly what you are doing.
Did your internet search not yield any results so you have to shout at us?
I found lots of results in 2 seconds. So can you!
Bye!
10/01/2015 3:40 AM
A better question to ask is:
"How to Search the Internet - 9 Easy Steps (with Pictures)"
Independence is a wonderful thing!
Re: Different Primary and Secondary Clarifier Mechanism
10/08/2015 6:05 PM
Simplistically speaking, the mechanism of a primary clarifier, in a waste water treatment plant, is to let gravity do all the work to draw the larger particles down to ''settle out'', individually.
Similarly, the mechanism of a secondary clarifier is to let some of the largest remaining particles (coalesce) enough to become heavy enough to settle-out as a ''floc'' of (several/many) smaller particles, collectively.
Good luck with the rest of your homework...
10/09/2015 2:14 AM
Thank you sir
Register to Reply 7 comments
IdeaSmith (2); lyn (1); MR. Guest (1); Original_Macgyver (1); saritarkd (2)
