Previous in Forum: Insulation Resistance Test for Alternator   Next in Forum: Calculator Off-Mode VS. Cell Phone Sleep Mode
16 comments
Power to Varying Resistance
10/19/2015 4:37 PM
Can a regulator be built to divide the output of a DC power source to supply identical amperage, in the range of 1 to 5 Amps, to 16 individual conductive parts in an electrolytic solution
Said parts are connected to the system with varying contact resistance. It will be required that voltage to each different location will be controlled to assure the amperage to each part is constant
The parts would be plated in an electrolytic solution.
The desired end result will be the delivery of the same amount of charge (number of coulomb's) to each part.
Pathfinder Tags: power supply
Re: Power to varying resistance
10/19/2015 4:44 PM
Do these parts have varying surface areas? Any blind holes?
It's surely doable. Is it necessary is the question?
Hobbies - CNC - New Member
10/19/2015 4:44 PM
What are you trying to plate?
What is the base material?
What is the plating material?
Good Answers: 804
10/19/2015 4:51 PM
Current feedback loop to a variable DC voltage controller? Commonly made products.
Re: Power to Varying Resistance
10/19/2015 5:10 PM
10/19/2015 5:25 PM
Put the parts in series.
10/19/2015 7:58 PM
Ah, you beat me to it. The most elegant solution (pun not originally intended). But of course, this would require sixteen separate plating baths.
10/19/2015 6:08 PM
Yes. It's called a current mirror. Google it.
Good Answers: 225
10/19/2015 10:16 PM
That would be fine if all of the parts are of the same size and shape. If they are different, then they will require different current rates to achieve similar plating thickness in the same time frame.
Hanging the items off a non conducting rack and providing each with a constant current regulator would allow you to tailor individual currents to suit each item whether similar or different in size.
10/20/2015 2:52 AM
This appears to me to be a simple Ohm's Law question.
The plating current needs to be correct for the "area" of plating, I would guess that this is the reason for the variable current requirements.
It is quite easy with modern chips to control either the current, or the voltage quite accurately. Not a big deal.
The good point is that as already mentioned, if individual current control is organised, only one "bath" need be available.
I do believe (from a position of never having anything to do with metal plating!!) that something like a relatively simple PWM control, would be able to average out the current, seen over time, so that the end result is what is required.
Even a simple 555 circuit, controlled say by a potentiometer, with a MOSFET output may do it!! A current meter (even a simple one using leds and a control chip) , may be required for accuracy.
A lot here is simple guessing only, as the OP's information is not very extensive.....but I do feel that it should be quite easy to organise well.
Good Answers: 26
10/20/2015 8:29 AM
And the application is what?
Good Answers: 12
10/20/2015 12:58 PM
All good answers here. I think all here would agree, that how one approaches the problem depends on the results desired. We don't know enough about the problem. But, if this challenge belonged to those who answered here, they would have this problem solved, and moving on to finding better quality/efficiency in the process.
Invention is the mother of necessity.......there are always opportunities for improvement!!
10/20/2015 3:40 PM
More Info
The 16 parts are identical within the tolerances of the print. The contact is not permanently attached to each part. The part sits in and on the contact thus the variation in resistance due to variation in the part tolerance and contact fit. The DC power must be adjusted for each part to ensure the amperage is identical in each part thus resulting in consistent plating thickness. Voltage of individual power sources will range from 3.5 to 6 Volts.
10/20/2015 4:21 PM
Let me complicate this further.
Having equal current applied at some point to the part may not insure even current density over the entire surface, so you may still see inconsistencies. Most, but not all, plating specs have a minimum thickness requirement. It would be difficult to control plating thickness to microns over an entire part, depending on the size.
It would be interesting to know your end requirements for thickness, and the motivation for such control.
Different metals plate at different rates and require different current densities, as well.
10/20/2015 4:30 PM
Refer to #2.
Like you said Lyn, the part geometry will affect the plating too.
We're just spitting in the dark without more info!
10/20/2015 6:23 PM
If all the target devices are connected in series the current through all of them MUST be the same, then it is only a case of boosting the dc voltage to the level required to achieve whatever current you require.
11/06/2015 6:34 AM
www.linear.com/docs/1059
One per circuit and adjust each to the desired plating current.
Register to Reply 16 comments
Andy Germany (1); Brave Sir Robin (1); John Afonso (1); JohnDG (1); JRaef (1); ka5s (1); lyn (2); Original_Macgyver (3); Rixter (1); spades (1); texasron (1); WAWAUS (1); wolfie62 (1)
