Previous in Forum: End of the Rainbow   Next in Forum: Grey Water Recycling-Simple Domestic Application
United States - Member - Go Tigers! Engineering Fields - Mechanical Engineering - Specialty - Mechanical Vibrations Fans of Old Computers - UNIVAC - Man I shoulda bought a Whirlwind!
Hydraulic Cylinder
07/23/2007 1:38 PM
Hello-
I just wanted to ask if anyone knows of a reputable supplier of small bore hydraulic cylinders. I've done web searches and have found some equipment that might work. However, I am hoping for some feed back from other Engineers.
Specs on what I need
  • 0.5"-0.80" Bore
  • 5"+ Stroke
  • EPDM or BUNA-N Seals
  • 2000PSI +
I'm looking for feedback from others, I've been searching the web and Globalspec already and will continue to do so.
Thanks,
fm!
"Your theory is crazy, but it's not crazy enough to be true." - Niels Bohr
Re: Hydraulic Cylinder
07/23/2007 3:34 PM
Without searching their specs to your description, Parker, Enerpac, and PHD make reputable cylinders. I have had very good luck with Parker. You may want to, if you haven't already, contact a local distributor and pick their brains. Most are engineers and have a solid understanding of the application.
“Do or do not, there is no try” - Yoda
07/23/2007 4:53 PM
pls contact me on my email ssujeer@yahoo.com with application details and clear specs like mounting etc.
07/24/2007 9:10 AM
You may want to contact TMC Hydraulics, Temple, TX 254-774-8099 or Texas Hydraulics 254-778-4701.
regards
HL
07/24/2007 12:01 PM
A cheap version is a "Bimba", But you can't go wrong with a Parker.
We use a lot of Bimbas on our equipment but they are standard 120psi actuators.
To be or not to be - that's pretty much all there is...
07/24/2007 3:35 PM
Bimba and Clippard both make small cylinders.
07/24/2007 10:08 PM
Hello Everyone!
Thank you for your kind replies. The equipment I'm developing will be used to evaluate auto braking systems. I'm strongly considering using a "race car" master cylinder however most do not provide an adequate stroke length. I fear using a bore larger then 3/4" (which most recommended suppliers provide) due to input force requirements (less than 1000lbf for 2000PSI output). I guess it may help for you all to know that I intend to use the cylinder in reverse, I will be using a servo motor / linear actuator to provide force to a hydraulic cylinder with the hope of generating a pressure of at least 200PSI. Well, continue with the excellent suggestions!
fm!
08/01/2007 4:49 AM
Hi:
Is it a cusmtom-designed ? Tie rod or welded? clevis end or tube end? I do hydraulic cylinder business selling both custom made and popular size cylinders and curious what type of cylinder you are looking for. I may of help for getting what you want.
You can email me at ynjusa@gmail.com for your need and my nake is Zuo.
Good luck!
Register to Reply 7 comments
Anonymous Poster (3); Camillion (1); Facilities Engineer (1); fattmaxx (1); HarryBurt (1)
