Previous in Forum: Is Voltage Rating Important in Fuses ?   Next in Forum: Placement of Flooded Lead Acid Batteries in Panel Rooms
100 kVA
11/27/2015 9:03 AM
Dear ALL
shortcut to calculate the amp is it 100kva X 1.41 = 141amp
Any advise please
Thanks
Good Answers: 140
Re: 100kva
11/27/2015 9:16 AM
No...
You cannot calculate amps without knowing the voltage as VA is "volts x amps". The "k" means 1000 VAs.
Re: 100kva
11/29/2015 1:49 PM
The shortcut is you assume the voltage.
Re: 100kva
11/27/2015 10:06 AM
This works every time. Try it!
Shortcut to Calculate AMPS
Anonymous Poster #2
Re: 100kva
12/17/2015 6:08 AM
you think that posting how to search it in internet would really help? Instead of not giving the correct answer, why can't u just not respond or go to the lawn and water the grasses or if u r hungry eat them, enjoy the life ol'man.
Reply Score 1 for Off Topic
Re: 100 kVA
11/28/2015 8:33 AM
Dear Friend,
100 KVA = 100 x 1000 VA. If Voltage is 420, (in 3 phase) then the Current = (100 x 1000)/420 = 238.09 Amps. Hence 100 KVA x 2.38 238 AMPS. From where you got this factor 1.41.?
Perhaps for HP x (1.41 ) = Current in Amps will hold good, provided Voltage is less than 420 Volts, since Power = Sq.Rt.3 x V x I x Cos. Phi and HP = KW/(0.75)
DHAYANANDHAN.S
Anonymous Poster #2
Re: 100 kVA
12/17/2015 6:04 AM
bayangaram sir neenga
Good Answers: 181
Re: 100 kVA
11/28/2015 10:14 AM
Shortcut? I wrote a spreadsheet of all the calculations I use.
Write it once and you can do your own homework quickly in the future.
412.393051V
Anonymous Poster (2); dhayanandhan (1); jack of all trades (1); lyn (1); North of 60 (1); TonyS (1)
