Previous in Forum: Progressive Cavity Pump   Next in Forum: Gas Engine Block Damaged
Australia - Member - New Member Pakistan - Member - New Member Engineering Fields - Automotive Engineering - New Member
Fuel Consumption
12/01/2015 10:55 AM
I have jenbacher gas engine in my power plant coupled with alternator and it is 3 MW Generator, now when i run it on 2 MW load it consumes lot of gas, so the fuel consumption is increased if u guys have some good points regarding this please update
be sincere to your work...
Good Answers: 70
Re: Fuel Consumption
12/01/2015 11:56 AM
The first thing you do is read the operator's manual
(2) Hire a competent operator
(3) Contact the factory representative
12/01/2015 11:58 AM
Contact the factory.
Free advice, from people half way around the world is not worth much.
Go to the manufacturer's website for advice.
Good Answers: 181
12/01/2015 11:59 AM
Run it at 1MW to save fuel, run it at 3MW it will use more fuel.
What do you expect it to do, produce power out of fresh air? Power produced and fuel consumption isn't linier.
Contact the manufacturers or RTFM.
Good Answers: 122
12/01/2015 4:20 PM
Judging on your post about suffering engine damage I would surmise you have hit on the root-cause of the damage.
Something is wrong with the engine fuel system and/or mechanical components.
Things to look at:
1) Engine timing. (Per factory specifications? Stable or floating/changing?)
2) Fuel quality. (Correct octane? Correct fuel? Alcohol content?)
3) Fuel injector or carburetor condition and operation.
4) Timing gear, timing chain, or timing belt condition.
5) Cylinder compression. (Bad valves and/or excessive cylinder clearance.)
6) Engine vacuum. (Loose components and/or leaking components.)
7) Restricted air intake. (Plenum scaling/buildup, plugged air filter, animals/birds caught in the intake screen.)
8) If equipped with sparkplugs and distributor or magneto then closely examine and replace as needed.
9) Excessive engine wear.
Hope this helps.
12/01/2015 11:00 PM
Does the manufacturer's tag say "Product of Chrysler" ?? They tend to guzzle gas when under load. Sounds like a "blow by" problem with worn rings and burned valves.
dj95401 (1); lyn (1); SHOCKHISCAN (1); TonyS (1); wayneelowe (1)
