Previous in Forum: What Should Be the Capacity of Steam Boiler to Run a Turbine to Produce 1MW   Next in Forum: Fuel Consumption
15 comments
Progressive Cavity Pump
12/01/2015 8:41 AM
Dear gents I need Standard maintenance procedure (SMP) for 20 HP powered progressive cavity pump please help..
Pathfinder Tags: cavity pump
Good Answers: 76
Re: Progressive Cavity Pump
12/01/2015 8:45 AM
The procedures should be in the O&M (Operations and Maintenance) Manual for said pump. If you do not have the O&M Manual, contact the OEM (Original Equipment Manufacturer) and request one.
12/01/2015 10:03 AM
...by telephone. It's quicker, and cannot be ignored.
12/01/2015 10:20 AM
Hai gentle man What are you saying
Good Answers: 76
12/01/2015 10:55 AM
He means "call the manufacturer and ask them"
12/01/2015 11:35 AM
Ok Thahks guys
12/01/2015 12:03 PM
Crystal ball is broken.
Carnacthe Magnificent is dead.
Call the manufacturer or look at the MANUAL!!
Danfoss Group 2 Gear Pumps
U.S. Seal Mfg. Catalog
Vantage Engine® Maintenance Manual
Good Answers: 117
12/02/2015 6:38 AM
There is no maintenance schedule for a progressive cavity pump as it only has one moving part. There is no maintenance required for either the stator or orger!!
What is the application for the PCP? what are you pumping? Heavy oil, peanut butter, live fish.....
What is the drive configuration? Single motor with drive gearbox and/or drive belts, double motor drive, VSD controlled, type of stuffing box gland for the polished drive rod.
The application will dictate the maintenance, as will all the other above mentioned.
12/02/2015 10:03 AM
Dear brich
Our pump is belt driven , for pumping light crude (offspec tank to separator )
I need the SMP because for attach with PTW while doing periodic preventive maintenance.
12/02/2015 12:48 PM
So, to clarify, you have a BDP, for pumping LC, and you need the SMP because for attach with PTW while doing PPM? Is that right?
12/02/2015 12:57 PM
Yes Clearly Yes
Good Answers: 122
12/02/2015 5:04 PM
WOW! That means we must not forget to first notify the NPI to ensure compliance with the EPA so that BHP doesn't get PO'd and FUBAR the WDT?
12/02/2015 5:08 PM
You must have been a BMOC in college.
Good Answers: 122
12/03/2015 8:59 AM
Ahh... Yes and I was considered by some of my dearest professors to be a SA however I pointed out that in every smart family there is at least one SA.
Good Answers: 122
12/03/2015 9:15 AM
I am a bit confused.
We have numerous pumps in our bulk fuel plants that appear to be the same as illustrated in your provided picture so it is entirely possibly we might have an Installation & Operations Manual (IOM) on file.
If you want good information on any equipment it is imperative that you include all pertinent information on the equipment such as:
1) Manufacturer name.
2) Equipment (pump) type. (From picture the pump appears to be a "screw" type possibly of the positive displacement type?)
3) Model number.
4) Size. (GPM, HP, Stages,?)
5) Duty cycle. (Intermittent at "x"%, Continuous at 100%, ?)
6) Utilization of equipment in the process. (Transfer of light crude? Solvents? Gasoline?)
12/04/2015 8:56 AM
So why the heck didn't you post that picture in the original post, Mildred? At least then I'd have some idea of what you're talking about.
Did you ring the manufacturer? I'm not going to do that for you as that might make you lazy, and we don't want that, do we?
Good moaning!
Register to Reply 15 comments
brich (1); Crabtree (1); JavaHead (2); lyn (3); Narayanasamy (4); PWSlack (1); SHOCKHISCAN (3)
