Previous in Forum: Dimension Required for PN 160 Flanges   Next in Forum: Shell & Tube Falling Film Evaporator Nickel Tubes Collapsed
Standard for Pressure Vessels Permanent Nozzles Supports
12/10/2015 1:18 PM
Dear Experts,
Can i ask for permanent supports for nozzles in Horizental Vessels for Level Gauges Nozzles and other Nozzles .
Normally permanent supports are installed only in 2 Inch Nozzles when length has been increased almost 400 to 500 MM .
Thanks
Re: Standard for Pressure Vessels Permanent Nozzles Supports
12/10/2015 7:49 PM
I think that either as an end user, designer, or general contractor, you can ask for whatever convenience features you like, so long as they don't violate codes (e.g., by adding excessive weight or other loads).
12/10/2015 10:14 PM
Dear Sir,
test mail please i can explain with attachment and screen shot its too easy to understand .
thanks for reply .
Br,
MZI
CR4 ADMIN - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
12/11/2015 2:06 AM
You should avoid posting email addresses publicly, lest you attract spam.
Register to Reply 3 comments
