Previous in Forum: Selection of Pump   Next in Forum: Galvanized Duct Instead of Black Steel Duct
9 comments
Fabrication Of Dish End For Pressure Vessel
12/23/2015 1:47 AM
How Should I Get The Correct Quantity Of Plate Needed For Fabricating A Dish End Of Any Vessel.
Pathfinder Tags: Dish End
Re: Fabrication Of Dish End For Pressure Vessel
12/23/2015 9:09 AM
Just figure out how much you need and buy a little extra.
12/23/2015 11:39 AM
Calculus would be one way; another way is accurate mechanical drawing.
12/23/2015 5:55 PM
Just ask the people doing the rolling, Mildred! You can use the phone, can't you?
Good moaning!
12/25/2015 1:08 AM
I JUST NEED TO KNOW THE FORMULA TO CALCUATE THE PLATE NEEDED FOR FABRACTING DISH END
12/25/2015 1:20 AM
Shouting will not encourage any answers. Not only that, but until you state what shape the head is (hemispherical, torispherical, ellipsoidal, other) there is no formula. However, 1.57 D will cover all of these cases, unless you fail to center the disk properly when you spin it.
12/25/2015 11:47 PM
it is for hemispherical shape
12/26/2015 5:03 AM
The area of a hemisphere is 2 (pi) r2, with possibly some extra allowance for gripping it during the forming process. If made from more than one piece of plate, this can all change.
12/26/2015 11:47 AM
Normally circular blank is prepared for forming the dished end,the formula for the diameter of the blank required for the dished is
OD +OD/24+2/3KR+2SF
OD- Out side diameter of the dished end
KR- Knuckle Radius of the Dished end(Normally the Knuckle radius is 10% of the Out side diameter of the dished end
SF- Height of Straight Face Dished End(Normally 50 mm to 60 mm depending upon the size dished end)
12/26/2015 8:51 PM
The dished end are formed from metal sheets,the metal sheet req for forming dished end is called blank.The size of the blank can be derived from the following formula
Diameter of the Blank: OD + OD/24 +2/3KR+2SF,
OD - Out side Diameter of the DishedEend
KR- Knuckle radius of the Dished End(Normally 10% of out side of Dished End)
SF- Straight Face of the Dished End(Normally 50 mm to 60 mm Depends on the size of Dished End)
Register to Reply 9 comments
Crabtree (1); ellururamaiah (2); lyn (1); saiyed yasar (2); Tornado (3)
