Previous in Forum: Electromagnet sizing   Next in Forum: DG Set Rating
Transformer test
07/26/2007 10:01 AM
What is the overall test of a power transformer.
Re: Transformer test
07/26/2007 10:57 PM
There are three types of factory test named (1) Routine test (2) acceptance tests and (3) type tests. Normally, these test categories are standardised by varios codes and standards.
In transformer routine tests, I guess there should be dry frequency high voltage test, winding resistance test, insulation resistance/volume resistivity test, temperature rise test, Partial discharge test etc.
Accepatance tests are categories of test designed to witness by customer as agreed by manufacturers at the time of order placement to accept the lot of transformers ready for shipment.
Type tests are categories of test includes some distructive test too. At the end of type tests, the equipment is out of life and can not be used. Normally, these tests are conducted on one transformer selected randomly from a big lot of transformers.
There may be a list of test as follows.
Wet frequency high voltage test
Lightning Impulse test (1.2/50)
Switching Impulse test (0.2/50)
tan delta test
Heating cycle test
Insulation resistance test
short circuit tests
I think this may help you
Haresh Patel
09/13/2009 4:56 PM
Hiiiiiiiiiiiiiii
can any one provide me with the standerds of these tests????
THNX 4 HELP
09/13/2009 5:15 PM
Which country are you in? Please find out national standards of your country. Otherwise look brochure of IEC, IEEE, BS, IS, VDE etc to research applicable standards.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member Technical Fields - Technical Writing - New Member Engineering Fields - Construction Engineering - New Member India - Member - New Member Engineering Fields - Nanoengineering - New Member Safety - Hazmat - New Member
07/27/2007 9:58 PM
Where you came across, the requirement for 'Overall test' of a power transformer? Standards call for 'routine','type' and 'acceptance' tests. Please provide more information on,what is expected of such 'overall' test.
nvmani
Anonymous Poster (2); hareshptl (1); nvmani (1)
