Previous in Forum: Basic Doubt in Simulink Power System Simulation.   Next in Forum: RC Servo Control
23 comments
Hobbies - Musician - New Member Greece - Member - New Member
PCB Differential Pairs for Audio
01/08/2016 3:49 PM
Hi everybody. I wish you all a happy 2016.
I want to route an audio signal on a PCB design as a differential pair (it's a line signal of just a few volts) and I wonder if there is a "recommended geometry". Of course, for an audio signal the "characteristic impedance" of the diff. pair has no meaning and I assume that the signals (+) & (-) of the pair should be routed as close as possible to each other (closely coupled) for noise immunity issues. However, maybe there is a kind of "optimal geometry" (or not), although I haven't found an info about that. If you have any suggestions, please let me know.
Thank you.
George
George
Re: PCB differential pairs for audio
01/08/2016 4:47 PM
The primary thing I would recommend is to not put any "in band" signal traces between your differential pairs. Keep the differential pairs together on the circuit board.The current loop induced voltage will look just like desired signals. Since you're putting this on a PCB it will also be good to have a ground plane on the opposite side if only using two layers. With a multi-layer board ($) having ground and power as your inner layers and signals on the outer layer works very well. If you have to cross your low level and high traces, try to cross them only at right angles.
01/08/2016 5:01 PM
Good Answers: 918
01/08/2016 5:22 PM
Not much to worry about at the drive levels you cite. Here are some basics:
Keep the traces short and together.
Don't fret about the difference is trace lengths. That's not important at these frequencies.
Signal traces should cross at right angles and avoid parallel traces (ground traces are okay)
Don't mix digital and analog sections. try to keep each sequestered to their own area.
Split ground planes are not a de facto science between analog and digital sections. There are studies that show benefits and there are equally valid studies that say they are not important. Splitting a ground plane is tricky and can lead to issues. If you feel you want to go that route you must do your homework.
Sound power supply design and filtering are important.
01/08/2016 10:46 PM
Exactly. GA. (Don't let the Monster Cable mentality infect your thinking. People overthink the whole audio thing. Now if we're talking about LVDS at gigahertz frequencies, that's a whole other ball of wax. Bob Pease loved to tear apart various claims.)
http://electronicdesign.com/analog/what-s-all-splicing-stuff-anyhow-part-ii
http://electronicdesign.com/lighting/whats-all-hoax-stuff-anyhow
Good Answers: 918
01/08/2016 11:09 PM
Audio black magic exists because people don't understand the underlying physics of audio. People then get pulled along with group think with the rest of the uneducated crowd.
The response is to "be safe" and throw money at their ignorance, buying things that make little or no difference at all. The deeper their pockets, the more esoteric they become, proud of their folly.
01/09/2016 1:20 AM
Perception is reality
Probably nowhere more true than with regard to audio
Re: PCB Differential Pairs for Audio
01/09/2016 4:16 AM
Thank you all for your replies. However, they were not helpful at all.
I'm well aware of all these "tips" that you have mentioned. I'm very experienced at signal integrity and I have designed a great number of complex and high-frequency (analog and digital) schematics and PCBs in my professional career.
In my present project I have to route some differential pairs of audio signals and I wondered if there is an "optimal way" to design these pairs (I mean the "optimal" geometry of each pair). I.e. how close can the (+) and (-) signals of the pair can be to each other? Or how much the traces' width should be? So, I'm talking about the width and gap of the (+) and (-) traces of each differential pair.
George
01/09/2016 6:41 AM
At audio frequencies you probably cannot physically construct any PCB features that would make any difference.
RF is a totally different critter.
Go with what's easiest.
01/09/2016 8:02 AM
01/09/2016 12:20 PM
That was interesting (although not helpful in my case).
It was interesting that the "loose coupling" is better than the "tight coupling", in the case where the two signals of the pair have to be further separated for a while (in order to come around an obstacle), as their impedance doesn't change much because of this.
However, I always prefer the "close coupling" (taking care not to change at all the gap between the traces throughout their entire length) as this approach provides a higher noise immunity (and lower radiation).
George
Good Answers: 918
01/09/2016 8:08 AM
Thanks for being clearer.
The best thing is to just keep the lengths short and away from sources of stray noise. Yes, we said that already.
Differential audio, if it is the typical 600Ω balanced line, is too low an impedance and too high a signal drive to be concerned with the details you are worrying about.
How do you Brits put it? Don't over-egg the pudding!
Good Answers: 918
01/09/2016 8:18 AM
If your traces are only a few cm long, 15 mil wide traces with a minimum 0f 15 mil spacing should be safe.
01/09/2016 12:26 PM
Yes, AH, I also believe that 15 mil width and 15 mil gap is OK in this case. This gap keeps the two traces close enough to each other (tight coupled) for high noise immunity.
Thanks.
George
Good Answers: 116
01/09/2016 1:11 PM
Theoretically, magnetic pick-up is minimal if wires of pair are very close together to minimise loop area and electrostatic if wires are very small. However, you mention some pairs, so it's best not to put pairs close together (a strong + signal to earth on an adjacent wire is not differential even if it has a - wire beyond it) . It might be that your major noise source is magnetic from your power transfo - in that case traces on opposite sides of board, rather than side by side may present the least loop area to the field direction. Telephone cables use twisted pairs and transpose the pairs along the cable so that same pairs are not adjacent all through the run - but within the size of a PCB I doubt any benefit.
01/10/2016 4:08 AM
You said: (a strong + signal to earth on an adjacent wire is not differential even if it has a - wire beyond it) .
I'm not sure that I understand this.
George
Good Answers: 116
01/10/2016 9:00 AM
Apologies, it was a bad way of saying that if you put pairs close together, the effect of the adjacent wire dominates over the the compensating pickup from the remote wire of the "interfering" pair. Twisting pairs and transposing pair position in a cable are ways of reducing the effect of small spacing between pairs, this applies particularly to the modern ethernet where twisted pairs have mostly replaced coaxial cables. This began in the days of open wire telephone lines, which are more like the PCB arrangement, you can put the tracks side by side or on different layers but cannot twist them.
67model
01/10/2016 9:21 AM
This is true for a cable but multiple vias through a Printed Circuit Board (PCB) will greatly raise the board cost for little to no benefit. However, putting the connector close to the input circuitry so a shielded, twisted pair cable can bring the differential signal with the least amount of interference.
Good Answers: 918
01/10/2016 9:44 AM
This discussion is like putting Class 3A threads on a sewer pipe.
The designer is going to need to work pretty hard to inject noise and hum into a 600Ω balanced line driver's output signal path.
01/10/2016 9:51 AM
Sometimes one does have to know how and if one can convert a sewer pipe into a UHV vacuum chamber.
Good Answers: 116
01/10/2016 10:19 AM
He never said it was 600 ohm. It could be a low impedance driver with high impedance amp input load at other end.
Good Answers: 918
01/10/2016 11:36 AM
True. I don't know what other standards of differential audio drivers there are that are not low impedance.
01/10/2016 5:16 PM
Yes, that's exactly what it is...
George
01/10/2016 5:35 PM
Yes, now it was clearer... Of course, the wire of "the aggressor pair" (e.g. the +) which is closer to the "victim pair" affects the latter a little more than the other wire (e.g. the -) of the "aggressor pair" does.
George
Register to Reply 23 comments
67model (3); Anonymous Hero (6); Brave Sir Robin (1); G.K. (6); redfred (3); SolarEagle (2); zzorb (2)
