Previous in Forum: EagleSolar   Next in Forum: Wiring Diagram for a Thorn 42 CNC
FEA - Material Properties
01/10/2016 9:57 AM
Hi,
In my company we have a new FEA software package and we would like to obtain stress-strain curves for various materials we design our components with. The software comes loaded with pre-defined materials however, one of out clients wanted us to verify our FEA with their supplied stress-strain values which are slightly different to the software's data. Can anyone recommend a useful resource/name of a book/references that I can use to obtain the values for materials?
Pathfinder Tags: FEA Materials
Re: FEA - Material Properties
01/10/2016 10:30 AM
No.
You can find GENERAL materials properties with a search.
Specific properties can only be determined by testing that material.
Matlab has typical properties.
The material manufacturer is the only source of specific properties.
01/10/2016 12:13 PM
Use your client's data for constant. Lyn is right. There must be a feature of the FEA software to let you input customized value of material. Otherwise, the software is a waste.
01/10/2016 6:06 PM
Hi Thanks for your response. We are indeed using the stress strain values in the FE analysis given to us by the client and the software allows for custom inputs. I will try to source that info from material supplier... Thank you.
01/10/2016 7:11 PM
<...source that info from material supplier...>
Correct.
Register to Reply 4 comments
adcar (1); lyn (1); Mr. small (1); PWSlack (1)
