Previous in Forum: Microsoft Heats the Ocean To Save Cash on Their Electricity Bills   Next in Forum: "Shrunkfitted on Tapering Threads"
Genetic Algorithm Optimization in Matlab
02/02/2016 4:47 AM
I have to find the global minimum of a function which has 11 independent variables using ga
[X,FVAL,EXITFLAG] = ga(@FitnessFunc, 11, [],[],[],[],lb, ub, [],INTCON, options);
Some of these variables are integer. This function has a lot of local minima, and I am not able to locate the global one. I tried to increase the Population Size and Generation but the resulting solutions are always trapped in regions that are worse than the optimal one ( I know what is the solution of the problem because i found it in literature).
Can you suggest me how to set the other options of the Genetic Algorithm (Crossover, Mutation, Selection...) in order to resolve the problem ( I think I have to increase the diversity in the population).
I read about a particular technique called "niche technique" or "niching algorithm"; it uses knowledge gained during one usage of GA to avoid re-searching, on subsequent GA usage, regions of problem space where solution have already been found. Consequently, the likelihood of discovering a new solution on each iteration is increased. Do you know if a Matlab script of this technique is avaible, or if it is already implemented in Matlab ga toolbox?
Thank you.
Pathfinder Tags: Genetic Algorithm Matlab
Re: Genetic algorithm optimization in Matlab
02/02/2016 9:08 AM
Annealing, perhaps?
02/02/2016 11:33 AM
Re: Genetic Algorithm Optimization in Matlab
02/02/2016 3:16 PM
02/02/2016 7:23 PM
Experiencing first-hand the obstacles of "intelligent design"....
Register to Reply 4 comments
Mr. small (1); SolarEagle (1); Tornado (1); truth is not a compromise (1)
