Previous in Forum: Electromagnet Switch Timer   Next in Forum: Power Generation from Alternator Using Induction Motor
Stability Test for Generator
02/10/2016 1:35 AM
Would anyone say what is the acceptance level/criteria for Stability Test?
actually we are performing this test to confirm CT connections are set right. In this case acceptance criteria is achieved if differential current value doesnt exceed pickup value?? if any other means to be considered please guide me. Thank you
Re: Stability Test for Generator
02/10/2016 1:46 AM
02/10/2016 3:10 AM
Turn it upside-down. If it turns itself back right-side-up, then it is stable. If not, then not.
02/11/2016 11:45 AM
I anticipated that your comeback as; 'give it a shove, if it falls over it is not stable"
Good Answers: 445
02/10/2016 11:19 AM
This seems like a very convoluted way to "...confirm CT connections...". Are you assuming that if the unit remains stable then the connections are correct, how do you measure "instability", and what does differential current have to do with stability? You do know that if the connections are incorrect the control/protective systems will not operate properly and you could damage the unit.
Do it the proper way, hire an engineer experienced in commissioning a unit to guide you.
02/11/2016 4:56 AM
Anyone could say that it is pointless carrying out the test in the first place if the boundary between a successful outcome and an unsuccessful one were not determined beforehand!
Good Answers: 181
02/11/2016 6:58 AM
You've never worked in R&D then? (Wreck and Destroy.)
"Was it supposed to do that?"
"No, and I need an excuse, quick!"
I always blamed the boss.
02/11/2016 7:26 AM
Whatever.
Register to Reply 7 comments
Anonymous Poster (1); IQ (1); lyn (1); PWSlack (2); RAMConsult (1); TonyS (1)
