Previous in Forum: injection molds/extrusion   Next in Forum: Procedural Format to Track Fixtures?
Laser Cutter Verses Turret Punch Press
07/30/2007 9:03 AM
Laser cutter verses turret punch press
The situation is that part of our company ,the sheet metal fabrication part, we have some punch presses that do most of the work but we farm out allot of the cutting to another shop when it comes back we press brake some of it and/or other things to finish the product.The thing is we want to bring all the farmed out work, back to our shop. The problem is their all small quantity jobs 50 to 1000 at most. So building new die sets is to costly but a turret punch press or a laser cutter may be the way to go with present work and newer jobs not yet received.We cut all steels up to .156 of an inch or 4mm thick with various lengths of cut. My question is what would the pros and cons related to this situation and laser cutters verses turret punch press or other be. I know one would be the laser cutter is slower and more versatile then the turret press and the laser cutter requires no tooling to be made or bought. Price new used ? Any other pros and cons please share
thank you
Help me with the things i don`t know . I`ll try to help you with the things i do know and we`ll both get smarter
Re: Laser Cutter Verses Turret Punch Press
07/30/2007 9:30 AM
There was a good article a few days back on water jet cutters...might be worth a look.
07/30/2007 9:31 AM
here I found it...
07/30/2007 6:56 PM
In a past life our shop had both the water jet and a laser cutter.
Operating costs are pretty high on the jet. Size is (was) pretty big. Everything got wet.
Laser cutter was fast (so was jet). Laser was quieter and smaller in size, with lower op costs. Laser tended to leave a better edge. Both ran on simple software.
for smaller/thinner materials the laser for sure. you can also pick up some plastics work.
I don't mean to knock the jet, but it is a monster. If you are cutting plate steel, thick plastics and much larger stuff then there you go. But they are heavy consumers, loud, dirty wet, expensive to maintain and service (service cost is high on the laser too).
I encourage you to ask what else can this tool bring into the shop. Where else might we generate revenue as a result of acquiring this equipment. Also you might find thta some existing work is well suited to one vs the other thus freeing up existing equip.
CR3
Engineering Fields - Manufacturing Engineering - United Kingdom - Member - Get things done!
07/31/2007 3:00 AM
A friend of mine has a Bystronic laser that can cut up to 25mm stainless. Very quick, very clean, no looking back...we run 4 punch presses processing plastic coated material. A laser would do, but at a higher cost due to re specifying the material...
'The truth is out there' The lies are in your head.
07/31/2007 6:20 AM
Is there any reason that you haven't mentioned plasma cutting? I think this would be a low cost - high productivity alternative to expensive punch press tooling and expensive high maintenance lasers.
07/31/2007 7:29 AM
I have worked at places that have had either a laser or a turret press as well as places that have both. From my experience what is best for you will be determined by what your products typically look like. A Laser can be very quick, quiet and efficient as long as it continues to cut once it starts. So parts with complex profiles work out well. But lasers lose speed once there are a large # of features inside the part, cutting a large quantity of holes etc. Plus a laser will not be able to embosses and other types of features.
A turret will handle the internal features better, special tools can be made to create the geomtry in a single strike but when cutting a profile you will see "nibble" marks that can be quite sharp, but can also create problems with brake tooling, inconsistent burrs that alter the repeatability of the forming process. Plus the lighter duty turrets have real problems handling the heavier gauge material.
Since you have punch presses already I would say either a laser or even a plasma/punch. The one I saw can handle very thick material, that way you have the ability of a lasertype system but also the punch press.
07/31/2007 8:33 AM
You should investigate a CNC Plasma Cutter.
Relatively inexpensive, fast, versatile and leave a fair edge.
Maintenance is easy.
Register to Reply 7 comments
Anonymous Poster (2); PlbMak (1); prbarry (1); TexasCharley (1); user-deleted-1105 (2)
You might be interested in: Punch Presses, Industrial Presses, Tool Turrets
