Previous in Forum: regarding super capacitors   Next in Forum: Electronic frequency conversion 50Hz to 60Hz
8 comments
FG Wilson generator
07/30/2007 11:10 AM
Hi,
Can someone help me find a service manual for an FG Wilson 350 generator set?
Re: FG Wilson generator
07/30/2007 12:09 PM
07/30/2007 2:07 PM
Thanks but apparently they do not post the manuals
Engineering Fields - Piping Design Engineering - New Member Technical Fields - Architecture - New Member
07/30/2007 11:20 PM
FG willson packages and markets Caterpillar perkins engines giving the cerialNumber of your engine contact your nearest Caterpillar perkins office i dont know where you are located,If you are in UK it would be much easier.Try perkins web site or contact Caterpillar power generation web sites and post a request.
crm
Run silent run deep
07/30/2007 11:39 PM
I think they like to know where the manuals are going and to whom.
They custom manufacture for nearly every application.
Why not write them?
07/31/2007 12:13 AM
you are right in india Fg wilson packages Generators with Any engine avilable and cheap .But its worth contacting Perkins UK if the engine is perkins even though FG wilsons are part of Caterpilar U S A In India Caterpillar doesent have any control over FG Willson!
crm
Run silent run deep
07/31/2007 5:09 AM
If your countery of location is not Brazil then your generator engine should be Perkins.Follow the link(Techenical support perkins) to contact perkins they, will tell you how to go about and contact perkins destributer in your countery
http://www.perkins.com/cda/components/fullArticle?m=96904&x=7&id=304870
good luck
crm
Run silent run deep
07/31/2007 3:38 AM
When U say Generator i take it as generating set. The three major components are the Engine, Alternator,and control Panel. Engine and alternator u can get from respective manufacturers as already suggested by everyone.Normally they use Stamford or Leroy somer alternators whichcan be had from them. Pl check serial nos and write to them. The control panel is locally made and u need a wiring diagram which may be difficult to get. But contact the guy who sold it to u.he may be able to help.
08/01/2007 7:16 PM
Hi, send me your request for which type of manual you need and the long ID number which starts usually with FGW and then the number and letters. mostly I can get them. You can contact me here www.global-energy-gambia.com best regards Milko
Anonymous Poster (3); crm (3); Global energy (1); Moto (1)
