Previous in Forum: JCB 4CX Backhoe   Next in Forum: Sulphur Hopper
Euro 5 Conversion
03/03/2016 12:15 AM
Is it possible to convert a Mercedes Benz Sprinter 2010 from Euro 5 back to Euro 3 due to poor fuel quality where I live (Diesel)
Re: Euro 5 conversion
03/03/2016 12:22 AM
Whom better to ask than Mercedes-Benz?
03/03/2016 1:27 AM
Have you tried any fuel additives? Are you asking is it legal? Do you know exactly what the problem is with the diesel you are using?
http://www.bellperformance.com/blog/bid/110843/Diesel-Fuel-Additives-Top-5-Things-You-Never-Knew-You-Didn-t-Know
Sprinter....
Re: Euro 5 Conversion
03/03/2016 3:15 PM
I'm sure it can be done. I'm not sure if it is legal to do this. There might even be a simple, legal modification to your Euro 5 compliant engine/fuel system that can handle your local blend of fuel. Contact your local Mercedes dealership or approved mechanic.
03/03/2016 4:10 PM
Depends on what they changed on the vehicle's engine to meet the euro 5 standards.
https://www.theaa.com/motoring_advice/fuels-and-environment/euro-emissions-standards.html
If it's just a matter of tearing the guts out of a particulate filter and bypassing a few other mechanical emissions devices like an EGR valve and makeing the engine think they are still working by modifying sensor signals then yes it could be done (legal or otherwise) without too much work providing you are mechanically inclined and a bit clever.
But if they went with a whole different engine and fuel system design like being all electronic drive by wire Vs the old all or near all mechanical injection then no it's not likely you could do a fuel and emissions design rollback yourself and you would be time and money ahead to go and find a older vehicle.
03/04/2016 12:11 AM
This will run just fine on just about anything including salad oil.
Brave Sir Robin (1); redfred (1); SolarEagle (1); tcmtech (1); Tornado (1)
