Previous in Forum: Maximum Differential Pressure for Gas Pipeline Ball Valve   Next in Forum: Home Heating System Control Question
SA516 Plate Material for Wet H2S Service
03/24/2016 9:04 PM
The licensor has specified LTCS material for stripper column in wet H2s service. In the Material specification , KCS with 6mm corrosion allowance is specified and also the requirement is for HIC test and PWHT. The MDMT is -22 deg C as per datasheet. My query is whether to use SA516Gr 60(N) plate or SA516Gr 70(N) plate.
Thanks for the answer..
Pathfinder Tags: SA516 for wet H2S service
Re: SA516 plate material for wet H2S service
03/24/2016 9:51 PM
I would contact your metal supplier to see what they might recommend...I would think either would work, but your supplier might have some better information about their product specific qualities....and you might go into greater detail...I would say from what you have said that the SA516Gr 70(N) would do nicely...but I am not an expert in this area and do not possess all the pertinent information...
03/24/2016 10:00 PM
Contact a supplier and ask them. They are the experts in their field.
If they think you will buy from them, they will help you.
UK +44 (0)1782 450 910
U.A.E 8000 3570 3670
Brazil +55 11 3958 8070
Stainless +44 1922 748 710
Singapore +65 315 86991
A516 Grade 60 | SA516 Grade 60 - Brown McFarlane
A516 Grade 70 | SA516 Grade 70 - Brown McFarlane
Grade 70 is just normalized Grade 60.
03/24/2016 11:47 PM
The surprisingly large corrosion allowance of 6mm would lead me to consider another class of material. (I'm not familiar with what is best for H2S service, though.)
Whatever material you are using, calculate the required thickness. If you can use a lesser thickness of a stronger material, the weight reduction may save some money. This becomes an economic decision of comparing possible alternatives.
Good Answers: 181
03/25/2016 7:51 AM
How about asking the licensor first.
Register to Reply 4 comments
lyn (1); SolarEagle (1); TonyS (1); Tornado (1)
