Previous in Forum: Gasoline Expansion Puzzle   Next in Forum: Small Birds' Vision: Not So Sharp but Superfast
14 comments
Split Bolt Connector with Balls
03/29/2016 9:40 AM
What are they for? Came across this splitbolt connector, one of the balls is missing but the other one moves up and down on that little rod?
Any ideas
( mods this is a serious inquiry not a joke)
Re: Split bolt connector with balls
03/29/2016 9:54 AM
Can you post full picture of the connector ?
Where/what is this from(application) ?
Normally it's used to connect cables/wires and such, but balls..... ??
Moving in/out, but that's normally used as tension indicator in specialty bolts.
Did Indecent Exposure create the need for darkroom ?
Good Answers: 266
Re: Split Bolt Connector with Balls
03/29/2016 12:16 PM
Good Answers: 18
03/29/2016 11:54 PM
NO:2 OzzB,
That is a tie rod end for a 1960s -1970s International Harvester Cub Cadet Lawn Tractor, I have 4 new ones, had them for 50+years just looking for a use. I just cant throw things like that away.
For every great advancement in medicine there is an equal and opposite advancement in the denial of treatment.
03/30/2016 2:04 AM
Ebay 'em....$$
Good Answers: 225
03/29/2016 2:20 PM
I've only ever used the female version, it's quite unique...maybe if you remove the other ball it will be quite eunuch. sorry, couldn't help myself.
Good Answers: 70
03/31/2016 6:35 PM
I'll keep my legs crossed, thank you
03/29/2016 4:59 PM
Did you ask this dude?
I've never seen, nor heard, of such a thing.
03/30/2016 9:20 AM
Naaaa, he only knows horses
03/30/2016 2:13 AM
Well if the rod is attached to the separator, the amount sticking out could be used for determining proper tightness by wire compression measurement...maybe a prototype that never panned out....
03/30/2016 7:46 AM
If you are not sure what it is, how do you know a ball is missing?
03/30/2016 9:22 AM
The other side has a hole and broken rod in it. But yes I assumed it had one on the other side.
The rod and ball does not seem to be connected to the pressure plate.
Good Answers: 70
03/30/2016 11:15 PM
"The rod and ball does not seem to be connected to the pressure plate." -- what pressure plate? Is there more to the story?
03/31/2016 5:18 AM
GA
I did a quick image search for split bolt connectors, and, they are invariably used to joint electrical connections, sometimes for tensioning wires.
Good Answers: 70
03/31/2016 6:29 PM
Being I've been away for a while I'm glad to see the hater's are still with us!
To me and like some many other threads here, there's always more to the story.
I've used wire splices that are set up in a similar fashion but not with a ball as a contact point.
Can you post a more defined picture of this?
Register to Reply 14 comments
dj95401 (3); horace40 (1); Jerrell Conway (1); justthecowboy (2); lyn (1); ozzb (1); Ramm (1); Randall (1); SolarEagle (2); spades (1)
