Previous in Forum: Frozen Suction and Compressor   Next in Forum: IKEA Recalls Defective Allen/Hex Keys
Calculation of FAD
04/01/2016 6:07 AM
first you have to find FAD for individual outlets and add all of them together, then you will total capacity of your compressor(FAD)
here,
we have formula,
Q(FAD)=[QN×(Ti+273)×1.013]/(273×Pi), unit L/s
where,
QN=flow of air from respective outlet, unit should be in L/s,
if some time the unite is in Nm3/min,
so u have to convert it,
which is, 16.667NL/s
Pi=pressure at ambient temperature=1 bar
Ti=ambient temperature.
Re: calculation of FAD
04/01/2016 6:57 AM
And...?
Re: Calculation of FAD
04/01/2016 11:35 AM
You left a step out:
Q(FAD)=[QN×(Ti+273)×1.013]/[Then a Miracle Happens)(273×Pi), unit L/s
04/01/2016 12:08 PM
FAD = frequently added dimensions
04/01/2016 4:01 PM
Cooling BTUs = CFM x ∆h x 4.5
• CFM = The fan CFM plotted on the fan tables, or measured at several points in the system
• ∆h = the enthalpy change through the system (we get this number by converting wet bulb readings.)
• 4.5 = the cooling BTU multiplier at sea level, or .075-lbs. of air per CFM x 60 (minutes in an hour.) This factor will also change at higher altitudes. BTU multipliers will also change due to extreme air temperatures.
http://contractingbusiness.com/archive/system-delivered-btu-calculation-basics
http://www.uigi.com/WebPsycH.html
Good Answers: 137
04/02/2016 4:28 AM
The square brackets [] are superfluous
04/03/2016 11:26 AM
AP?
Codemaster (1); JohnDG (1); lyn (1); Mr. small (1); SolarEagle (2)
