Previous in Forum: Attached Picture Clarity Problem.   Next in Forum: Pad Mounted Containment
Stress Analysis Software
04/08/2016 2:40 AM
Hi all
I have an elderly 3D package which has no stress analysis capability which in most cases, I don't need. I would like to use a 3rd party software, any suggestions?
Thanks Tony
The nice thing about Standards is there are so many to choose from.
Pathfinder Tags: stress analysis software
Re: Stress analysis software
04/08/2016 4:37 AM
Re: Stress Analysis Software
04/08/2016 11:52 PM
if you want it cheap or free, here's a list you definitely should check out
http://www.freebyte.com/cad/fea.htm
04/09/2016 2:23 AM
Thank you Mr small, that is a fabulous link.
I have downloaded LISA and I'll see how I go with that.
Tony
Good Answers: 183
04/10/2016 4:15 PM
I use it since many years and I am very satisfied. It depends what you want to analyse. It has no "contact elements". The price is very attractive and the person in charge is making a tremendous work in giving support.
If you need more then look at CALCULIX which is free.
04/10/2016 8:16 PM
Thank you Nick Name, what program are you referring to in your first paragraph?
Tony
04/10/2016 8:35 PM
Having not used any of these FEA programs, I realise the learning curve is huge. I touched on this subject 35 years ago when studying, but haven't since, using shear and tensile calculations on the important bits. Nothing has failed, but I'm probably over designing.
Thank you Solar Eagle for your contribution, that had some interesting information.
Tony
Good Answers: 183
04/11/2016 3:23 AM
To LISA.
I started to use it when it was still at #5 or 6. There are some problems with it but if you do only do mechanical stress/strain analysis it works pretty well. it has the advantage to offer the possibility to get easy values along a frontier and transfer them to excel for a curve build up.
Register to Reply 7 comments
Mr. small (1); nick name (2); SolarEagle (1); Tonymech (3)
