Previous in Forum: The Best Chemicals to Manufacture   Next in Forum: pickling process
Wanted: European Valve Manufacturers
08/02/2007 4:07 AM
Hello !
I am searching for manufacturers or suppliers able to furnish the following valves, only from french, italian, german, dutch norwegian origin :
- choke valves
- wells pressure reducing valves
- pressure reducing valves
- oil stream pressure reducing valves
- christmas tree valves.
The general specifications are as followed :
API 6A TYPE H2, API MATERIAL CLASS (HH)
FLANGE WORKING PRESSURES : 3000PSI RING TYPE JOINT R37
NORMAL SIZE 4"
MAXIMUM ORIFICE 3"
INLET (4 1/16) "API 3000
FLANGE OUTLET (4 1/16)" API 3000
OPERATING TEMP : 0-180º F
Many thanks for quick answers.
Re: Wanted: European Valve Manufacturers
08/03/2007 2:45 AM
Hi,
You could try GHR at Ober-Morlen in Germany
or IMF in France
08/03/2007 7:34 AM
Do you consider Israel as Europe? (at least for that purpose) Than go to www.dorot.co.il They build Excellent valves. you can also Google BERMAD they also have a wide variety of valves
Wangito.
Never trade luck for skill.
08/03/2007 5:22 PM
what about rexroth
Register to Reply 3 comments
You might be interested in: Control Valves, Gas Valves, Industrial Valves
