Previous in Forum: Should Voters in PA Ban Fracking?   Next in Forum: Why Are Some of Us Not Threated by the Web's Location Feature?
24 comments
High Voltage Questions
04/25/2016 11:41 PM
I have generated a High-Voltage spark which jumps a 30mm Spark gap. What would an estimate of the voltage be for such a spark. How can I test to determine if the voltage is AC or DC? What diode/circuit can I use to rectify it if it's AC to a DC voltage? What Diodes are capable of handling such voltages?
Pathfinder Tags: DC high voltage
Re: High Voltage questions
04/25/2016 11:47 PM
So you have a high voltage spark and want to know the voltage? Well I guess it was high!
Voltage AC or DC? Really? How did you generate the Voltage?
You are possibly playing with your life here. So better read up and learn before doing.
Diodes have ratings. Try not to define the Voltage by touching blank wires unless you know what currents flow in your system.
You are trolling this forum, right?
Good Answers: 54
04/27/2016 1:33 AM
Good advice! You may have saved this guy's life.
04/26/2016 12:14 AM
Bill's sister is his brother's mother. His next door neighbor is his father's uncle.
What is his father's name?
No, it's not Dad!
Good Answers: 54
04/27/2016 1:33 AM
Bill Cosby?
Good Answers: 70
04/26/2016 1:42 AM
You've been a member of this forum since Nov. 2013 and this being your first question(s). And not knowing how you created a high enough voltage to jump a 30mm gap? You need to stop where your at and find a friend or somebody that knows what they're doing with electricity, because you obviously don't and could be the making of a Darwin's Award winner. We don't know what your input voltage is/was, AC/DC or what kind of transformer you used to step up the voltage.
You need to get yourself educated in electrical theory before you kill yourself and maybe a friend too, that's dumb enough to watch your little experiment.
04/26/2016 2:28 AM
The HV is generated by an ne555 as an oscilator driving my own wound primary on the ferrite core of a TV transformer. Due caution is taken & a chicken stick is used as a probe. Some hv tv transformers have an inbuilt rectified to produce the HV DC but I am not sure if mine has it built in.
04/26/2016 8:26 AM
What's the chicken stick for? What is needed is a book and a handful of experience in electrical and HV engineering and safety practise.
Stay safe!
04/27/2016 8:55 PM
Thanks to all for all the valuable advice which is greatly appreciated.
The chicken stick is a dowel stick (mine is about 750mm in Length) and is used as a probe for sparking.
The HV output insulated wire from the TV transformer is only attached at the end of the stick.
The other end of the stick away from the & HV wire, is only held.
I am working on a glass topped table and keep far away from the HV Transformer and the wire attached to the Chicken Stick. After I run the circuit I switch it off, disconnect the power and discharge it by shorting the HV lead to Ground.
An NE555 is connected as an oscillator generating Square waves and feeds my own primary coil wound on the TV transformer.
I previously experimented with a Cockcraft Walton circuits with about 5 & 10 Stages also driven by an NE555 oscillator powered by a 9V battery to generate the high voltage but the voltage produced seemed to be very low as the spark was only about 1mm long. Maybe I used the wrong type of caps.
04/28/2016 3:50 AM
Well, looks like you are still alive. But as said before your experimental approach to electricity might get you a Charles Darwin award at its best or a shock (either electrical or from the fire insurance bill).
Your question is clear indication of missing knowledge and it might be wise to head some of the advice being given to read more before you turn the generator on again.
I would start with a definition what a "wrong type of cap" is. You can gain important knowledge on caps which you need when playing around with them.
What is it you want to achieve? Just the spark? Or anything more sinister?
Good Answers: 73
04/26/2016 2:18 PM
Since your 555 is most likely producing a square wave the TV transformer is charging up the ferrite with magnetic energy while the output of the 555 is high (i.e. conducting current through your primary coil). That energy is being released all at once when the current is suddenly cut off and the voltage spikes because inductors do not like to have the current flow disrupted.
The formula that would calculate the peak voltage requires specific knowledge about amount of stored energy, characteristics of the ferrite type, and number of windings on the high side as well as some other things.
Because it is driven by a square wave, it is not DC. It is bursts of energy that has the potential of overheating your transformer due to high currents for a short amount of time. When you get the spark, you are more or less creating a short circuit at the output of the transformer. Don't look for it to survive very long.
04/26/2016 3:48 PM
Well it better as TV transformers can produce enough current and voltage to kill.
What exactly are you trying to do or build as there is likely a much safer way to get the same result?
04/26/2016 6:49 PM
Be very careful...
Is the output AC or DC?
You could connect the output of the HV to a high voltage capacitor (or Leyden Jar) and turn it on momentarily.
Check the voltage on the capacitor. If there is still voltage, there is a blocking diode and the output is DC. If there is no blocking diode (AC output), the capacitor will discharge back through the flyback secondary coil and there should be no voltage.
04/26/2016 10:47 PM
I ran the circuit with a small value 240V rated cap connected to the secondary for a second and checked for voltage on the disconnected cap. There was a very small spark from the cap when shorted.
Does this confirm that there must be a diode within the Transformer and a DC voltage is output?
Good Answers: 54
04/27/2016 2:08 AM
Syd, I'll tell you about another story. The output of your transformer is much higher than 240V. It's not safe.
Read my story about my childhood experience with transformers. I'll add something to our story. We had some 100V caps sitting around - electrolytics. We thought it would be fun to see what happens when you run high voltage ac through them. Some just leaked, while others exploded. We were smart enough to run long leads of wire and to place the caps around the corner. We did the same test with diodes and transistors. Most did nothing, but burn out, but a couple did explode.
The moral of the story, don't put a 240V cap on a high voltage transformer. Yours is rated for 240V and I know you have much more than that.
Good Answers: 73
04/27/2016 12:28 PM
No. The capacitor charges because it is the collapse of the magnetic field always in the same direction. The peak voltage is always positive (or always negative) with respect to ground because when the 555 turns off, it is always disrupting a charging cycle in the same falling edge. This is because the portion of the square wave that charges the magnetic field is always of the same polarity. There is no energy put into the magnetic material when the 555 is in the off state.
Good Answers: 70
04/26/2016 9:37 PM
Back on the farm, I had a 17 hand Stallion I couldn't keep corralled in an 8 foot barb wire fence. And that's what your trying to do here. Experience is expensive, rather it's live stock or live electricity. It takes a through understanding, to be able to corral hot stock! They both will bite you in the ass, when your not look'n!!
Good Answers: 54
04/27/2016 1:53 AM
Okay Syd, I'm going to let you know about an experiment I did as a kid and yes, my friends and I all survived.
My friend's brother had "acquired" some big transformers (from large neon monument signs). We hooked the primary to 120VAC and the secondary we hooked up some carbon rods with lots and lots of electrical tape, which we used as handles. We got some pretty big arcs going. No, we didn't use any eye protection, so I'm pretty sure we burned up something in our eyes. We then used our home made welder to melt glass and we did some other cool stuff. I got a good shock when I brushed against the outside of the transformer with my arm.
So, I am not recommending you do anything like what we did. I just had a story to tell.
A little advice; don't mess with high current, high DC voltage. Also, if you get shocked with AC current, make sure your hands can't clamp down on the electrode - touch things with the back of your hand. Also, if you're going to get shocked, make sure it's on one arm. If the current goes from one arm to the other, it'll go through your heart - your heart doesn't like that. My best advice is to learn about safety working around high voltage before paying with it.
04/26/2016 3:02 AM
A1) In dry air, around 90kV or so.
A2) It depends upon whether there is a transformer with an alternating current feeding the spark, which the forum does not know as the equipment cannot be seen from here.
A3) Google "high voltage rectifiers".
A4) as A3.
Good Answers: 181
04/26/2016 6:37 AM
Much depends on the shape of the arc gap something a jacobs ladder relies on.
I'll echo the warnings given by others, HV isn't something to play with if you don't know what you're doing.
04/26/2016 11:04 PM
What was the voltage used to produce these effects & how did you generate the voltage?
Re: High Voltage Questions
04/26/2016 9:38 AM
Good Answers: 70
04/26/2016 9:18 PM
This guy/girl is over their head and any further information provided to them could lead to their demises.
The OP Has Not Provided Any Information That He/ She Has Any Idea Of What They Are doing!!
> UN-SUBSCRIBE<
04/27/2016 3:05 AM
Sounds like questions for a quiz.
If not, you are playing with lightning that doesn't always act like you would think.
HV and Rf burns are no joke.
Sorry to sound like a broken record but learn and understand, at the very least, basic electronics before even bothering to study High Voltage.
Playing with TV parts can have some very HV and have killed people who thought they knew what they were doing.
04/27/2016 1:32 PM
Just had a thought. If you are going to experiment with this type of high voltage why don't you switch to automotive coil with points.
If it bites you it will hurt like hell but you will probably live.
Learn why and how with some basics studies.
Just my two cents worth.
Register to Reply 24 comments
Autobroker (4); dj95401 (3); IdeaSmith (3); jack of all trades (1); lyn (1); NotUrOrdinaryJoe (2); PWSlack (1); Rixter (1); SolarEagle (1); Syd (4); TonyS (1); U V (2)
