Previous in Forum: how to calculate disel consumpation   Next in Forum: Pipeline corridor width for oil and gas pipelines
liquid ring pump
08/04/2007 2:47 AM
liquid ring vacuum pump calculation details from sart to end for designing system
Re: liquid ring pump
08/04/2007 9:21 PM
"liquid ring vacuum pump calculation details from sart to end for designing system"
Liquid Ring Vacuum Pumps
You can find more at <Google.com> & Dogpile.com>
Good Answers: 19
08/06/2007 9:08 AM
Obtain product and technical data sheets from the manufacturer selling you the liguid ring pump.
Vacuum flow rate from the point of pickup can be a tricky thing if you are in a manufacturing environment with long distance from the pump to the point a vacuum is used. If any appreciable distance is involved, you will need to factor in one or two increases in pipe size to minimize vacuum loss in the distance traveled.
You might be interested in: Metal Ring Seals, Liquid Level Switches
