Previous in Forum: What Happens To The Photons Generated By Laser Cooling?   Next in Forum: Fan Regulator Using Arduino
Phase Shift Across Transformers
06/11/2016 2:24 AM
Hi,
It is normal to have a generator transformer with a vector group dYN. On our system these transformers are dYN1. All through the transmission network, there is no phase shift as transformers are YNyn0. The phase shift only happens again across distribution transformers which are Dyn11.
If I use a distribution transformer of Vector group Dyn1 on this network, without paralleling it with the existing Dyn11 transformer, would this have any impact on the customer(s)?
Thanks.
Re: Phase shift across transformers
06/11/2016 3:47 AM
Good Answers: 181
06/11/2016 4:34 AM
So long as you don’t try to parallel them your customers won’t know the difference.
Re: Phase Shift Across Transformers
06/12/2016 12:18 AM
A transformer connection . . . dYn just does not exist.
06/13/2016 10:35 AM
The only customer issue would be if a fault condition occurs in the transformer at some future time. If the Dyn0 transformer fails for any reason, the customers will have an outage or at least a grid bump as the lines are switched to the other transformers. Depending on how fast the switching works, the customer will potentially see the 11 degree phase shift as the load shifts from the zero degree shifted source to the 11 degree shifted source. This is because the transformer is essentially stand alone.
Those customers on the paralleled transformers wouldn't see a major change as the load would transfer to the paralleled transformers.
Good Answers: 445
06/13/2016 11:09 AM
Ummm, the 11 doesn't stand for 11degrees, it represents the number of 30 degree shifts from zero going clockwise. In this case it means either 330 degrees or, as a power engineer would read it, -30 degrees, from the reference vector.
06/13/2016 12:25 PM
OK, so 11 "hours". Same issue.
Register to Reply 6 comments
Jpfalt (2); olehwi (1); RAMConsult (1); SolarEagle (1); TonyS (1)
