Previous in Forum: Hole Cutting   Next in Forum: Delinking of crosslink EVA/LDPE FOAM
8 comments
Hi-Temp Epoxy
08/04/2007 3:10 PM
Hi,
I'm looking for a strong high temperature (about 860 F) epoxy to attach sheet aluminum. Has anyone had a good experience with any? Any suggestions?
Steve
Pathfinder Tags: "high temp" Epoxy aluminum
Re: Hi-Temp Epoxy
08/05/2007 10:42 AM
I don't think any organics can withstand that temperature. Think brazing!
Re: Hi-Temp Epoxy
08/22/2009 7:37 AM
Thanks for the answers, fellas... as luck would have it, a mate of mine in the aviation industry has the sheet metal workers on the job making me a stainless steel expansion chamber!! Fully tig welded.
Only down side is a weight gain for the beast...never mind, it does come for free, so I am definitely not complaining, here!
Thanks guys
Daz
Go Hard...or GO HOME!!!
Re: Hi-Temp Epoxy
08/06/2007 8:27 AM
A company called Sauereisen has made high temperature cements for spark plugs, spark igniters, etc., for many years. They are not epoxy resins, but they might have a product that would work in your application. They have a website where you could contact one of their application engineers.
Popular Science - Weaponology - Aerospace nut Hobbies - Musician - music enriches the soul United States - Member - Happy to be from the USA Engineering Fields - Acoustical Engineering - Pro Audio Speaker Designer Engineering Fields - Manufacturing Engineering - Aerospace ME Engineering Fields - Aerospace Engineering - Airplane nut from aeromodels to 747's
Re: Hi-Temp Epoxy
08/06/2007 12:58 PM
another company that makes "inorganic" read ceramic adhesives is Toagosei. www.toagosei.net I've had some limited success with aluminum but any bonding at these temperatures gets difficult/
Scooter
The early bird gets the worm, but what about the early worm? A.E. Neuman
Re: Hi-Temp Epoxy
08/06/2007 6:37 PM
I am not sure if this temp is too high for J-B weld. I have used is successfully on an engine block.
Re: Hi-Temp Epoxy
08/06/2007 11:48 PM
I was thinking JB too. depending on exactly what you are doing jb gets pretty messy and would not spread very thin. Many epoxies have fillers sucha s titanium or aluminum or such.
JB is worth a look though.
Re: Hi-Temp Epoxy
08/14/2007 12:14 PM
JB Weld is good up to 600 F. I'm looking at it to test proof of concept at a lower speed, or for the first stage vehicle. This discussion has moved to
High Temperature Adhesive. FYI.
steve
Re: Hi-Temp Epoxy
12/02/2008 5:27 AM
G'day, fellas, I was just thinking the same thing...I searched this topic, and found this forum (I am a newbie here)
I need to find a Hi Temp epoxy resin to fix a 2 stroke expansion chamber made from lithographic plate (alloy thin sheeting)
A good mate of mine made the "pipe" to suit a 44cc chainsaw engine I'm using in a 1/4 scale RC drag car...(can you post images here?)another thought.....look here
http://www.quarterscalelegends.com/bb/viewtopic.php?t=485&start=60
anyhow, silly me sanded it down to make it look nice. I fired it up on the weekend, and POP! I split the divergent cone at the seam. (Not happy, Jan!!!)
what would be the best way to epoxy the pipe back together???
I will use plasterer's mesh tape to give me a tension proof substrate, along with a medium to build coats. I looked at ITW polymers, and a titaninum based epoxy resin seems a good way to go - hi temp properties, along with thick viscosity.
I want a finished product that can handle exhaust temperatures, and I can play baseball with the thing!!!!
Any thoughts????
Register to Reply 8 comments
Anonymous Poster (1); dkwarner (1); Muddy (2); sda1950 (1); silvCrow (1); snewkirk (1); TexasCharley (1)
