Previous in Forum: Hi-Temp Epoxy   Next in Forum: High Temperature Adhesive
Delinking of crosslink EVA/LDPE FOAM
08/05/2007 4:05 AM
We have crosslinked Foam scrap of EVA / LDPE. We want to delink the above pl advice.The above mentioned is peroxide cure.
Re: Delinking of crosslink EVA/LDPE FOAM
08/06/2007 7:18 AM
I don't believe this can be done- once you uas a peroxide you are crosslinking the material.
08/06/2007 9:17 AM
Guess you want to recycle. Don't think you can do it.
Wangito.
Never trade luck for skill.
08/09/2007 12:55 AM
Once the bond has been made the only way is to skive it ( cutting it with a horizontal band saw) to try to get as close to the seams as possible. If you want to grind it up, we have used large grinding wheels to make into smaller pieces. What do you want to do with it? Hope this helps.
Re: De linking of crosslink EVA/LDPE FOAM
08/09/2007 8:59 AM
Cross-linking is done on the molecular level, Don't see how cutting will change anything. Once crosslinked, there's no (easy) way back. And if our poster wants to recycle, X-linked polymers will not melt.
Wangito.
11/29/2007 8:04 AM
Do you mean cross linked or laminated foam, eg. EVA/LDPE/EVA layers composition ?
Coming together is a beginning. Keeping together is progress. Working together is success. Henry Ford
Anonymous Poster (1); marine boy (1); Sal (1); wangito (2)
