Previous in Forum: low noise microwave amplifier   Next in Forum: Investigation of CIM setups
Hot melt adheshive sheet for carpet backing
08/05/2007 4:12 AM
We require hot melt adhesive sheet for hand tufted carpet . At present we are using latex for carpet backing. As letex consumes lot of time in drying . looking for hot melt adhesive which melts and impregenate in to the piles of wool and then thermosets.Due to which strength of tufted carpet improves too.
Best Regards
Naresh Tagra
Re: Hot melt adheshive sheet for carpet backing
08/06/2007 9:05 AM
You can use 6" wide carpet tape, and using a 6"wide seaming iron, you can melt the tape from the backside. It might be easier if you try it out on a sample piece before you go and risk a $2000 or $3000 rug hand-tufted piece of artwork. I've been doing custom inlays for 20 years, cutting all the pieces to fit, then flipping over the main body, and adding all the pieces from the back. Then I'll lay a length of carpet tape over the added piece, and heat it up by putting the seaming iron on the back. Be sure to get it good and hot, to allow for perfect adhesion.
Waterman
08/06/2007 11:01 PM
Good advice below, also try Morton Adheasives, out of Rockford Il. If memory serves me they could what you need. They have a thermomelt vinyl weave for tile parque that may also work.
You might be interested in: Hot Melt Adhesives, Hot Stamping Foils
