Previous in Forum: A Little Spark Could Turn Your Sight Sharp   Next in Forum: Can I Use A PLC Instead of A Power Supply
Float Battery Chargers in GRID/Power Plants
07/08/2016 2:22 PM
Hi ,
i search a lot on internet but i didn't get clear, about Floating means and Non-Floating .
need little explanation about below lines
"Under normal conditions of station generation, the storage battery units are kept floating in DC bus bars by means of the trickle chargers (also known as float chargers)"
Thanks
Re: Float Battery Chargers in GRID/Power Plants
07/08/2016 5:24 PM
A battery that is fully charged will tend to self discharge over a period of time due to internal leakage. To keep an emergency battery charged and ready to be used, a trickle charger is used to keep it charged. That is what is termed a floating battery.
I'm not sure why it is called that, but I suspect that it means "holding the voltage up", similar to water lifting a boat.
https://en.wikipedia.org/wiki/Float_voltage
Good Answers: 42
07/08/2016 5:30 PM
Many batteries remain as stand by or continuously remain in circuit with minimum dicharge and does not need frequent recharging .But such battery need to be kept on a very low continuous charge called float charge. This is required to keep the battery on full charge so that the very purpose of keeping battery for the emergency use will be met.The battery used for the power station ,Electrical substations , Telephone exchange and similar utility are always kept on float charge
read the link below.
http://www.powerstream.com/SLA.htm. There are are many more you can get if you google.
07/08/2016 5:39 PM
Bulk charging of batteries is done with current control. The charger will maintain a specified value of current and will adjust the voltage to achieve the desired charging current. This is a fast rate charge. It can be several amperes to tens of amperes or more depending on the capacity of the battery.
https://en.wikipedia.org/wiki/Battery_charger
A float charge maintains a specified voltage, e.g. 13.6 volts DC maybe for a six cell Pb-acid battery and adjusts the current up or down to maintain that 13.6 volts DC. For most batteries the float charge could be as little as a few milliamps or even less. It will depend on the size and the condition of the battery.
https://en.wikipedia.org/wiki/Trickle_charging
Many modern battery chargers have charging algorithms to transition from bulk charging to float or trickle charging.
(And then there is conditioning batteries, generally speaking of Pb-acid batteries where you charge to an even higher voltage, sometimes with pulses to eliminate sulfur from the plates.)
https://en.wikipedia.org/wiki/Battery_regenerator
Good Answers: 445
07/09/2016 3:43 PM
A bit of history may help explain the term "floating". Back in the days before all this modern electronic stuff, the batteries that powered the POTS (Plain Old Telephone System" and the protective relaying and control systems were called station batteries. There were huge numbers of them connected in multiple series and parallel banks, all powered off of crude (by today's standards) DC battery chargers, but with no way to tell the SOC (State Of Charge) of any particular cell without going around and randomly sampling the SG (Specific Gravity) of each one.
Someone came up with the bright idea of placing a specially calibrated hydrometer that was small enough to fit into the top of a cell, so that a quick look would tell the technician if the cell was in need of charging. If enough of the hydrometers weren't seen, the technician would increase the charge voltage until the majority of the hydrometers were visible. This was known as a (drum-roll) floating charge, and was usually controlled by a timer to prevent overcharging of the bank. Any cell whose hydrometer wasn't floating was deemed to be defective and was replaced.
Good Answers: 58
07/10/2016 4:45 PM
Although I'm not an expert on the details, my float charger keeps the battery charged with a very small charging current. When the battery voltage gets to the proper voltage, the charger shuts down completely. When the battery voltage falls below the preset voltage (for any reason), the charger comes back on. This prevents overcharging during long periods of storage.
Brave Sir Robin (1); RAMConsult (1); Rixter (1); V.I.Abraham (1); welderman (1)
