Previous in Forum: How exactly to Control Office Separation Safely   Next in Forum: Architectural Engineering Information
How Fast Can a Bearing Rotate?
07/22/2016 12:15 AM
Classic Bearings work to help one surface slide along another by minimizing the points of friction between the two. Imagine sliding a puck across a hockey table without using the air . There's friction at all points where the puck is touching the surface. But if you turn the air on, Suddenly that puck is racing across the table. OAV Air bearing has achieved 1.37mil RPM
Re: How fast can a bearing rotate?
07/22/2016 12:21 AM
This should be here: Commercial Space
07/22/2016 12:44 AM
For how long--one revolution?
Register to Reply 2 comments
