Previous in Forum: Accuracy Class of Core Balance Current Transformer (CBCT)   Next in Forum: Protection In Un Grounded System
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
Small Battery Questions
09/05/2016 2:01 PM
I know very little about batteries, so pardon what may be very basic questions. But is it true that all cylindrical batteries (AAA, AA, C, D) are 1.5 volts? So size doesn't matter? If so, is their longevity what differentiates them?
Also, what is it about a rectangular 9V battery that makes it different? Its mass is approximate to two AA batteries, yet it has the voltage of 6 AA's. Under what circumstances are 9V preferred over cylindrical batteries?
And finally, my main question... I have an issue with the coffee in my French Press getting cold before I'm done. I'm going to look into modifying an electric cup warmer (like a little hot plate) and integrate it into the press. Is there a combination of AAA or AA alkaline batteries that would be a reasonable choice to give me 160 degrees F for a certain amount of time? Say.... 50 hours, for example?
(And yes, I know that I could just transfer the coffee to an insulated container, instead)
Thank you.
Pathfinder Tags: alkaline batteries
Re: Small Battery Questions
09/05/2016 2:08 PM
Look inside and you will find 6 AAA batteries.
Batteries won't last long making heat.
Get an AC adapter and plug it into the wall is your fancy press in DC.
Battery 101 - the basics
Good Answers: 39
09/05/2016 2:20 PM
No, my fancy shmancy press is AC.
So basically what you're saying is that my idea is impractical? This may be why there are no cordless warmers of this type... because they drain battery life too quickly.
And that's a good to know fact about 9v. I had no idea. Thank you.
09/05/2016 2:37 PM
Some electronics require more than a few volts to function.
9V are used in the case of portable radios to power the speaker and my IR thermometer is 9 V. Maybe that's because of the built-in laser pointer, don't know.
Insulated cup sounds good to me.
Good Answers: 39
09/05/2016 2:45 PM
Eh, I use enough insulated cups on the road. Not going to use them at home as well. Plastic lids aren't the same for appreciating good coffee on a weekend.
I'll probably try to cut away a slot in between the double steel bottom of my stainless steel press and slide the plug-in warmer in there. That will at least work better than the crappy insulating properties of the press itself.
Good Answers: 39
09/05/2016 2:30 PM
Thanx. That's a good site for the basics.
09/05/2016 3:57 PM
I took apart a 9 volt battery once. As I remember, it had horizontal layers, covered with some kind of wax.
09/05/2016 4:56 PM
Did I miss something?
09/05/2016 5:05 PM
Interesting. Maybe they make them differently nowadays. I have some dead ones in the basket of dead batteries to go to hazardous waste. I think I will autopsy some.
09/09/2016 3:57 AM
As a kid 50 years ago I opened one PP9 and it had 6 rectangular carbon paste cells stacked on top of each other with wax coating same as even modern PM9 9v battery. Today they are assembled using 6 AAA batteries as in Lin's picture.
09/05/2016 5:28 PM
Thanks, I stand corrected. I was a long time ago I ripped one apart. I suspect it was an el cheapo knock off battery.
Good Answers: 104
09/05/2016 5:44 PM
I've been educated, too. A long time ago, I took apart an old zinc-carbon 9 v battery and it had 6 layers, like you describe, best I remember. Looks like alkaline batteries are constructed differently.
Oh, yeah, here's one:
09/05/2016 5:52 PM
Three different kinds of 9-volt primary battery internals. (Left to Right) Rectangular cell zinc-carbon, rectangular cell alkaline, cylindrical cell alkaline.
And these batteries have become my personal favorite.
09/05/2016 7:54 PM
Thanks! I thought I was just hallucinating.
09/06/2016 12:19 AM
That is only one type of 9V battery. Another type uses a stack of little rectangular cells, vaguely similar to "button"cells.
I just recently took my box of dead batteries in for recycling, so I don't have any to dissect and/or photograph...
EDIT: I hadn't read the rest of the thread to see that Bigg beat me to it...
Good Answers: 54
09/07/2016 1:42 AM
http://goughlui.com/2015/05/05/mega-teardown-an-assortment-of-alkaline-9v-batteries/
Take a look at the Eveready Energizer teardown. I've seen these stacked 1.5V cells = 1 9V battery.
09/07/2016 9:50 AM
So it appears the series can cells is a more successful battery than the "stacked" cell battery? Or is it just that the mfr. can sell far more of the stack cell batteries to the general public so they need more volume production technique for that class?
Good Answers: 54
09/10/2016 12:46 AM
Good question. I wonder why a manufacturer chooses to produce a stacked cell battery vs AAAA's in series? I remember taking quite a few 9V batteries apart way back in around 1980. Back then it was the stacked cell type and I don't remember seeing one AAAA series type, so my guess is that it's the older method.
Good Answers: 225
09/10/2016 5:17 AM
There are pros and cons for both methods. The stacked 9v Carbon/Zinc PP3s use the Leclanche system (Zinc Chloride is not normally used for these batteries even though they exhibit better power density). The stacked method provides a greater energy to volume ratio due to reduced waste space as is found in grouped cylindrical cells. They are cheaper to produce - mainly due to the ease of series connecting the cells by simply stacking them together with a conductive Carbon film between adjacent cells.
The chemical equation for this combination is :- 2MnO2 + 2NH4Cl + Zn ZnCl2 2NH3 + Mn2O3 + H2O
The Alkaline (Alkaline Manganese Dioxide) equivalent of the Carbon Zinc PP3 is available with both stacked and cylindrical internals.It has several advantages over the C/Z chemistry in that it has a higher energy density, handles heavier drain currents with lower voltage sag (due to lower ionic resistance), has a longer shelf life and is less prone to leakage - doesn't produce as much water.
The chemical reaction at the anode is :- Zn + 2 OH- →ZnO +H2O + 2 e, however the cathode absorbs some of the water :- 2 MnO2 + 2 H2O+ 2 e → 2MnOOH + 2OH.
You will note that both chemistries produce H2O = water which also has a bit of acid in solution, and this is the downside of these cells. They tend to leak when discharged, and with most of these stacked cell batteries having a simple card type top and bottom which is not conducive to good sealing, the consequences for the appliance that they are fitted to is self evident.
The grouped cylindrical cells inside the PP3s are separately sealed and so offer far better protection against damage from leakage than the stacked variety, it also provides a slightly higher performance due to the more efficient arrangement of the anode and electrolyte enveloping the central cathode.
Although these batteries and cells are often claimed to be "leakproof", they will leak if the battery is allowed to become too discharged and the anode becomes perforated due to internal corrosion, or if internal pressure ruptures the case.
Another thing to be aware of with 9v batteries is that they can vary significantly in size, Energisers are 1/16" longer than Duracell, and many cheaper brands are wider (allows them to use cheaper materials). This can have implications for devices that are very tight on space as the replacement may not fit. For instance - some smoke alarms have a push in battery compartment where the incorrect battery may be too loose to make proper contact, or may not even fit the aperture.
Another question that often crops up is whether there is any advantage in purchasintg the more expensive offering from some of these companies. A lot depends on the intended usage, ie for low drain equipment, there is likely no advantage - a case in point is the Duracell Coppertop versus the Procell - significant difference in price, but at a low drain of say 10mW they both perform almost identically (both down to 8v in 250hrs), it's only when the drain rates get higher that the advantages of the higher priced chemistries becomes apparent - at 100mW the Coppertop is at 8v in about 15hrs whereas the Procell makes it to around 22hrs before 8v is reached.
Interestingly the Energiser EN22 has pretty much identical characteristics across the entire operational range as the (roughly twice as expensive) 522 industrial battery, so not much point outlaying more for the dearer one.
Good Answers: 54
#101
In reply to #65
09/16/2016 12:09 AM
Wow! GA to you!
09/16/2016 11:38 AM
Probably, it really comes down to speedy reliable automated manufacture of the ones with multiples of AAAA cells, that are made in a really fast line.
Good Answers: 54
#105
In reply to #104
09/21/2016 12:03 AM
I have a feeling it's mostly due to manufacturing efficiencies/costs.
I'm going to create a new post on leaking batteries. I just had some Duracell batteries leak in my cordless mouse.
In reply to #105
09/21/2016 9:59 AM
There is nothing worse than cordless mouse pee all over the desk top.
Good Answers: 54
#107
In reply to #106
09/24/2016 12:36 AM
Or on a mouse pad!
09/09/2016 6:58 AM
The batteries inside the metal case hoax has been around the web for a while. Snopes debunked it some time ago. The one I saw was a lantern battery shell with maybe 24 batteries in it.
09/13/2016 2:45 PM
4 A, yes? as in AAAA?
flash edit: I hadn't refreshed in awhile. Now I see several said yes, 4A
In reply to #96
09/13/2016 3:33 PM
I have called foul (OT) on myself for indication that the 6 cells inside a 9V battery were AAA when in reality they are AAAA.
In reply to #97
09/13/2016 5:25 PM
Oh......
So in other words AAA's won't fit.
In reply to #98
09/13/2016 5:29 PM
It's because of people like you that I lobby to ban anonymous posters.
In reply to #96
09/13/2016 7:47 PM
Quad-A, I think.
09/05/2016 2:22 PM
The voltage is determined by the battery chemistry. For example, carbon and zinc gives 1.5 volts. Nickel Cadmium (rechargeable) is 1.2 volts, lead / lead sulfate, 2 volts, lithium 3 volts, etc.
Common sizes in order of reduction in size are D, C, AA, AAA. There are other sizes but they are not common. 9 volt batteries are carbon/zinc cells (6 in series).
https://en.wikipedia.org/wiki/List_of_battery_sizes
Physically larger batteries have higher capacity (measured in milliamp hours or amp hours).
http://www.allaboutbatteries.com/Energy-tables.html
Find the energy contained in standard battery sizes
The table below shows the battery volume for cell sizes AAA, AA, C, and D. The volume does not change with the type of battery, but the weight does, as shown here.
Battery
Cell Size
Volume
ml
Alkaline
Weight g
Carbon-Zinc
Weight g
NiCad
Weight g
NiMH
Weight g
Lithium Ion
Weight g
AAA3.9129.71112
AA8.32419292624
C26.565488582
D55.813598200170
Energy storage in AAA batteries
Battery
Type
Avg. voltage
During discharge
milli-Amp
hours (mAh)
Watt-hours
Wh
Joules
J
Alkaline
Long-life
1.22511501.415071
Carbon-zinc1.13200.351268
Nickel-Cadmium1.23000.361296
NiMH1.28000.963456
Energy storage in AA batteries
Battery
Type
Avg. voltage
During discharge
milli-Amp
hours (mAh)
Watt-hours
Wh
Joules
J
Alkaline
Long-life
1.22521222.609360
Carbon-zinc1.15910.652340
Nickel-Cadmium1.210001.204320
NiMH1.221002.529072
Lithium Ion3.68533.111050
Energy storage in C batteries
Battery
Type
Avg. voltage
During discharge
milli-Amp
hours (mAh)
Watt-hours
Wh
Joules
J
Alkaline
Long-life
1.22578009.5634398
Carbon-zinc1.121722.398600
Nickel-Cadmium1.225003.0010800
NiMH1.245005.4019440
Energy storage in D batteries
Battery
Type
Avg. voltage
During discharge
milli-Amp
hours (mAh)
Watt-hours
Wh
Joules
J
Alkaline
Long-life
1.2251700020.8374970
Carbon-zinc1.147335.2118743
Nickel-Cadmium1.250006.0021600
NiMH1.2950011.4041040
Regarding your question of keeping liquids hot for a given amount of time, it depends on how well it is insulated and the ambient temperature. The energy supplied by your battery has to equal the heat loss through the insulation over the time period.
Good Answers: 39
09/05/2016 2:32 PM
Thank you. I guess there's a reason I didn't go into electrical engineering.
09/06/2016 12:47 AM
I find the voltages listed in those bottom tables disturbing! "Avg. voltage During discharge"? It should be quite clear that the voltage during discharge varies considerably depending on the current required by the load.
A Real-Time-Clock in a computer or machine uses almost no current, and can run for years on a single cell/battery, while an incandescent flashlight requires considerable current, and will last only a few minutes or maybe hours, depending on the cell size, number of cells, etc. The voltage of the RTC power cell will remain very near full voltage for most, if not all, of its useful life; the flashlight voltage will drop much more quickly, and by the time the cell voltage reaches that described in the tables, the flashlight will be essentially useless.
A new carbon-zinc cell should have 1.55V, if I recall correctly. If the average voltage is 1.1V, then the final voltage is 0.65V. What common device can operate down to a cell voltage of 0.65V?
I have a number of LED flashlights that run on 3-AAA cells. They stop working entirely when the cell voltage drops to about 1.3V. I have a number of those 1.3V cells, which I haven't discarded, hoping to find a device that can extract more energy before I recycle them.
09/09/2016 9:29 AM
use them in a clock
09/09/2016 1:06 PM
I thought about that, but then I'd have to replace the clock batteries more frequently...
09/06/2016 4:35 AM
GA. To complete the story, one can get AA-sized cells with Li-ion chemistry and an internal regulator to deliver 1.5V for a very long time.
Good Answers: 54
09/07/2016 1:44 AM
Nice tables!
Good Answers: 39
09/05/2016 2:39 PM
Actually, I'm better at figuring out alternate ways to get something done, rather than pushing my way through something I know little about. I'll come up with another route to get to what I'm trying to accomplish.
09/05/2016 4:24 PM
We used to use "thermos" bottles for hot coffee. They had an inner and outer silvered glass bottle with vacuum in between. (It's also called a Dewar flask.) The vacuum prevented heat loss by convection and the silvering heat loss by radiation. I think they'll keep coffee hot for about 24 hours.
https://en.wikipedia.org/wiki/Vacuum_flask
09/05/2016 4:18 PM
The family joules....
09/05/2016 5:40 PM
Not ALL cylindrical batteries are 1.5Vdc...ie: the CR123A is 3Vdc and cylindrical and looks like a 2/3's scale version of a 1.5Vdc C-cell.
Good Answers: 225
09/05/2016 7:58 PM
Not all cylindrical cells are 1.5v, depending on their construction, chemistry and intended purpose they can be as low as 1.25v, or as high as is required.
Some 2.13v lead acid cells are constructed in cylindrical (spiral) form as this creates a more efficient cell.
Some cells are constructed using a stack of button cells which adds their voltages in series to achieve the required value. The 12v A23 battery commonly used in garage door openers etc. is constructed of 8 LR932 (10 for the rechargeable type) button cells in a stack. The E90 or N is almost identical to the A23 but is a single cell of only 1.5v (1.250v rechargeable).
Standard rechargeables such as the AAA,C,D etc are generally only 1.25v. and so delivery lower performance than their alkaline equivalents.
Lithiums etc are generally 3.7v unless stacked for higher voltages, this is generally achieved with a group of pouch cells inside a cylinder.
9v batteries (PP3 type) are made up of a group of cells - either a stack of 6 carbon/Zinc or alkaline cells, or a grouping of 6 LR61 (AAAA) cells connected in series. Rechargeable 9v batteries have an extra 1 or 2 cells to account for the lower cell voltage.
Size does matter. The smaller the package then generally the lower the capacity.
Forget about using any of these for keeping your coffee warm as they will not deliver sufficient power for the job in a size that would be acceptable
Good Answers: 39
09/05/2016 9:26 PM
Thank you, you answered all my questions very clearly.
Back to the drawing board.
Good Answers: 54
09/07/2016 1:51 AM
09/12/2016 5:47 AM
I like you response because it instill self education/self help.
Good Answers: 54
#102
In reply to #76
09/16/2016 12:17 AM
Way back when I was in 5th grade, we had to take a science class. We did a lot of things with both sizes of lantern batteries.
Experimenting with batteries was a lot of fun. I often wonder if it's one of the reasons why I became an EE.
09/12/2016 11:27 AM
I suspect the 12V one will work better, since P = VI, so less current would produce the same quantity of heat in a given time. This might allow the battery "recovery" process to improve the next shot of current considerably, and so on, until it is drained.
A small 12V lead-acid battery properly charged between uses, is not too heavy to take with, unless you are walking, and do not want a battery in your backpack.
09/06/2016 5:42 AM
Other voltages are available, such as the BLR154, sometimes used in multimeters:
09/06/2016 1:58 PM
1. yes, the batteries are all approximately 1.5 V, consisting of precisely one cell.
2. 9V batteries are just that - batteries comprised of multiple (in this case 4) cells. Since the 9V batteries are 4 cells in series, the internal resistance gets multiplied by 4 at the output of the battery, hence these are not for high current draw.
You will want to use something other than these batteries to keep your coffee warm, seriously. Get a Thermos. Have you ever tasted 50 hour old coffee, really?
My French press is a vacuum jacketed stainless steel one. It keeps coffee warm until I drink my 2 cups worth.
09/06/2016 2:51 PM
You may have gotten some bad loco weed, unless those 4 batteries are special 2.25 V each.
09/06/2016 4:42 PM
Damned Chick-Fil-A salad greens! You are correct, there are six 1.5 V cells required to make 9 V, which multiplies the output impedance of one cell (as in the 9 V battery) by 6. I apologize with all due regret for momentary loss of math functions.
09/06/2016 2:54 PM
It looks like you need another cup...
That 1.5 V is VERY approximate, with full charge voltages ranging from 1.2-1.65V. From Wiki:
Since, as you say, AAs consist of a single cell, they really should not be called batteries; of course I do know that common usage, and even the packaging (at least on Duracell™ brand) use the term battery.
But your bigger error is getting 9V from 4 cells. It takes at least 6, and I'm virtually certain you knew this...
09/06/2016 2:59 PM
And I even showed him pictures. Go figger.
09/06/2016 4:53 PM
Really, I did not see any of the other posts, or I would have easily avoided my mistake. I was also on a sugar high from cookies at break this morning, and a Subway loaded sandwich.
09/06/2016 4:44 PM
No Lyn has been sniffing around my back shop, and found my supply of locoweed, and accused me of smoking it.
09/06/2016 4:51 PM
It really wasn't that good.
I've gotten better stuff out of a ditch in Arkansas.
09/06/2016 4:52 PM
I not have the benefit of seeing other posts when I replied, and I was in a big fat hurry, so much that I left out 2 cells in the "9V" battery, so it was really 6 V. BFS! (Big fat screwup).
None of the phonon cells I have made thus far are good for more than about 20 mA in bright sunlight for a heat source, but the sun does not need focused to the get things up to about 60 C, due to addition of a secret dark ingredient.
I hope to get some with 8" square sheets of magnesium going before too long, hopefully I will be able to get a uniform copper plate on one side, so stack making will be like stacking bricks.
09/06/2016 9:58 PM
You can get a lot of heat from a Lithium battery this way; https://www.youtube.com/watch?v=AAZ62tUtc0w Jim
09/07/2016 9:52 AM
I suppose that would re-warm the coffee, but would add to the bitter after-taste, and might actually medicate some psychiatric disorders simultaneously.
Didn't they use to use some form of Lithium to poison coyotes?
Good Answers: 22
09/08/2016 10:56 PM
I get your question... I think this is the kind of ballpark calculation you're after:
The real issue (on the heating) is your heat loss. You would express this in joules lost per second (or watts).
Whatever that is will determine the amount of energy you need your battery to put back in - again in watts.
Say you found your coffee went from 80 C (sorry - can't work in F) to 20 C in twenty minutes (that's from good hot coffee to room temperature).
Your average loss of heat energy is simple to work out. It's mcΔT - that is mass x heat capacity x temperature change.
So let's assume you have a few cups of coffee in your flask and it contains 0.5 kg of coffee. Let's also assume it's got the heat capacity of water (which would be a very good approximation for coffee) which is 4.184 Joules per gram per degree C. And we know the temperature difference is 60 degrees (80 - 20 C).
So in kilojoules you have lost 0.5 x 4.184 x 60 = 125.5 kJ (that's a lot of energy by the way - enough to lift your body about 400 - 500 feet into the air (there - did that one in non-metric for you ).
If your battery can put in 125.5 kJ, your coffee stays warm (this is actually misleading because your flask loses a lot more heat when it's hot than when it's cooler - you would probably have to at least double this ... so lets' say 250 kJ, or 250,000 joules).
To get watts you need to divide by the number of seconds. In 20 minutes you have 1200 seconds. 250,000 J /1200 seconds = 208 W
So you need your battery to provide a constant 208 watts. As an example your laptop probably uses less than half this. So if you used a laptop battery, you could keep your coffee warm for about half the time you can run your laptop... So a single fully charged laptop battery would keep your coffee hot for maybe 2 hours.
90 hours... you're looking for something over 45 laptop batteries.
(So I'm sorry - you're somewhat better off with the insulated flask).
09/08/2016 11:17 PM
GA!
I thought about doing those calculations myself, but haven't had the time.
I'm very used to Imperial measurements (much to my chagrin in US aerospace work), but I'd have done those calculations in metric as you did.
09/08/2016 11:38 PM
Could you run the numbers for 50 hours?
That's all the OP needed.
My back of the envelop numbers say the insulated flask is still a better choice.
09/09/2016 12:29 AM
The coffee pot in my coffee maker is a vacuum flask. I don't care for really hot drinks ( when freshly brewed, I have to pour a mug and let it cool a while before I can drink it), but even with my satisfaction with what my wife calls lukewarm coffee, even the vacuum flask can only keep it drinkable for 8 or 10 hours. I'm OK with day-old coffee, but I gotta reheat it.
For 50 hours, a fully charged automobile battery, might do the job, if the cup is pretty well insulated. ...not exactly portable!
Good Answers: 22
09/09/2016 12:46 AM
oops - 50 hours - I read it as 90 (it's called engineer-inspired scope creep )
So just 25 or so laptop batteries would do the trick - I suspect even a little more to be honest - but south of 40 I'd guess...
09/09/2016 1:06 AM
I have done one more simple calculation that indicates the using just 28 bushels of lemons, properly wired and changed out when depleted, would provide adequate power to keep OOTBE's coffee from becoming tepid for 50 hours.
So, at $48.00 USD per bushel the insulated flask looks very attractive.
09/12/2016 4:07 PM
Would the lemons be edible (fit for eating, raw, juiced, marmalade etc) after depleted in battery usage?
In reply to #86
09/12/2016 5:49 PM
Nope! They'd be contaminated with metals.
In reply to #86
09/12/2016 5:58 PM
That's roughly 2,500 lemons.
I would not know how suitable they would be for repurposing, but I doubt they would be unsafe if the areas used as terminals were excised.
You know what the say, "When life gives you lemons, make lemonade"
In reply to #89
09/13/2016 10:22 AM
You could make lemonade for the flies: Fly Killer
Good Answers: 39
09/09/2016 5:07 AM
Thank you. That's exactly the kind of information I was looking for, just to get a sense of what would be required.
Good Answers: 54
09/10/2016 12:49 AM
What about the conversion loss from electrical to heat. It's definitely not 100% efficient, so you'll need more than 208W.
09/10/2016 1:02 AM
That is about the only thing that is 100% efficient! All of the energy fed into a purely resistive device is converted into heat. Now there is also heat created in the battery itself, and in the leads connecting the battery to the resistance. so the battery and leads should be incorporated into the flask, but once again, the powr required makes it impractical.
Good Answers: 22
In reply to #59
09/10/2016 1:09 AM
Yes - agreed... but as you say, you're not likely to get all the heat into your coffee (having the battery immersed in the coffee would give you best bang for buck - but maybe pretty ordinary coffee!)
Good Answers: 54
In reply to #59
09/10/2016 1:12 AM
Whoops, that didn't come out right. Let me try it again.
Electricity will be used to power the heating element. Some of the heat from the heating element will be used to heat the coffee and some will be lost. Therefore, the efficiency of converting electricity to heating the coffee is not 100%.
09/10/2016 1:19 AM
Yep! You nailed it this time.
In reply to #59
09/12/2016 9:44 AM
Does the part of the energy that heats up the battery count in the efficiency calculation? Really?
In reply to #79
09/12/2016 10:54 AM
As I said,"so the battery and leads should be incorporated into the flask".
In reply to #81
09/12/2016 11:07 AM
Sorry! I missed that sentence, but I was slightly bleary eyed, half-awake this morning.
Good thing I am not a micro-surgeon, or even a height challenged surgeon.
Nothing left to see here. This myth is busted.
Good Answers: 22
09/10/2016 1:07 AM
Absolutely true.. but I already doubled the result to take into account the higher heat loss - I'm so ballpark already in that calculation I didn't think it warranted an efficiency conversion.
But for a good li-ion laptop battery taken from nominal 100% full to nominal 0% state of charge with a fast discharge rate you might be getting about 75% efficiency (i.e. a very fast discharge rate produces internal heat - running slowly in perfect conditions it might get more like 90% efficiency).
So the nominal 208 W is more like 156 W available.
I did a back-of-envelope for a single good quality deep-discharge lead-acid too. That (a 50 kg (110 lb) battery) might give you about 16 hours of hot coffee. Maybe 24 h if you drain it to empty, which isn't great for it :)
Good Answers: 54
In reply to #60
09/10/2016 2:34 AM
I think that either way, it's not an effective way to heat coffee or ...
I got it! How about using heat from a blow dryer! A suitcase size battery attached to a blow dryer! Absolute genuis! We solved the problem!
In reply to #64
09/12/2016 9:46 AM
A fold up bicycle with its own alternator, small battery, voltage inverter, and cup warmer, $500. Having coffee you might drink 50 hours later (and still enjoy it) - priceless. May I suggest some means of oxygen removal from the head space?
Good Answers: 54
#103
In reply to #80
09/16/2016 12:25 AM
Oxygen removal. Hmmm. I think you're on to something!
By the way, do you remember those old Schwinn bikes with the generator that rubbed on the side of the rear tire? Maybe that could be integrated into the fold up bicycle. Bicycle in a suitcase! Brilliant! http://www.nycewheels.com/brompton-hard-case-travel-box.html?cmp=googleproducts&kw=brompton-hard-case-travel-box&gclid=Cj0KEQjwjem-BRC_isGJlJ-0h-MBEiQAbCimWIBJig3aS-Wgj65GdvQbwGcBiFmHSki2uEErGKvqOGgaAuJG8P8HAQ
09/09/2016 11:05 AM
Ampacity. The battery voltage follow the rules of the periodic table, and the voltages are governed by that. A brand new alkaline battery is north of 1.6 volts. Lithium, silver, zinc carbon, lead, all different. The little 9 volt batteries have very little current output, and are a stack of cells in a rectangular package. Good for certain electronics. The material in a primary cell battery is consumed, bigger battery more fuel. A alkaline "D" battery can approach 20000 mAh.
09/09/2016 11:21 AM
This is what I got from a Chinese Supplier in email:
Hello
Amy's greeting here from HPL Battery in China.
Sorry if disturb,we are professional supplier of lithium batteries,following are some of our hot selling models:
12V-----80Ah, 100Ah, 120Ah, 160Ah, 200Ah;
24V-----40Ah, 60Ah, 80Ah, 120Ah, 160Ah, 180Ah, 200Ah, 250Ah;
36V-----40Ah, 60Ah, 80Ah, 120Ah;
48V-----40Ah, 60Ah, 80Ah, 120Ah;
220Wh Portable Power Pack:
Delivery time of samples in 7days after payment and in 15days for bulk order.
Images of the battery packs removed by me.
09/09/2016 1:21 PM
The voltage potential of any single cell is limited by the difference in oxidation potential between the cathode and anode, minus whatever voltage loss (resistance) from the electrolyte. Dig out your old freshman chemistry book (you did keep that, right?) and find the oxidation potential table and see the differences, You can come up with some exotic combinations that might be much higher than 1.5 volts, but the problems with those cells would limit their use and reliability. Current output, in milliamps per whatever time frame you want is going to be a function of how fast the chemical reaction can occur, driven by the reactivity of the anode and cathode (electrodes), the total surface area and distance between the electrodes and motility of charges within the electrolyte solution. In a sense, electric cell science and corrosion science are the same thing.
An example of available charge/discharge rates can be made using the type of 12 volt batteries used in automotive or marine applications. All the 12 volt (usually these test at 13.8 volts, truth be told) automotive batteries (a battery is technically an assemblage of more than one cell) generally have 9 individual cells. These have traditionally been lead/acid batteries, having lead anodes and lead sulfate cathodes in an acid electrolyte.
A single cell in this type battery may actually consist of multiple folds of lead and lead sulfate plates each connected in parellel, and the cells connected in series. If this type battery needs to deliver a large amp load, for example to turn a large bore, cold internal combustion engine to start it, each cell will be made of many thinner lead/lead acid plates, so there is a large surface to deliver more amps quickly, and to be recharged by the engine's electrical system for the next start.
A battery which must deliver a steady stream of power over a longer time (usually called a deep cycle battery), with a lower peak amp load, for example to run an electric cart or wheelchair, or electric boat motor, will have fewer, but thicker plates so it is more durable for long discharge and recharge cycles.
The same principles will be true for hearing aid batteries or watch batteries (actually, mostly these aren't batteries but cells). Simply looking at voltage of a cell tells us little about the actual delivered power, and the smaller the cell, the less total amperage will be. No magic in any of this.
Real men don't set for stun!
09/09/2016 1:59 PM
Where did you see a 12V Lead Acid battery with 9 cells? You set that type character upside-down.
09/09/2016 2:32 PM
Whoops, should have taken my own advice. 2.1 volts per cell in a lead acid battery, based on oxidation potential. 6 cells.
Good Answers: 54
09/10/2016 12:57 AM
a 12V car battery has 6 2V lead acid cells. That's why the old batteries had six separate caps. The newer ones have two caps with vents for three cells. Or some are maintenance free sealed batteries where the caps don't come off, unless they're forced off.
09/12/2016 2:21 PM
Just a slight correction, a Lead Acid car battery deliver Starting amps at 9V that is why in the old days with Coils and ignition points the sparking system used a 9V coil with a load resistor operated by a relay for direct conection of the coil to the battery under starting conditions and then when you let go of the starter position on the key the relay activate and put a in line resistor in series with the coil that will drop 4.8V of the 13.8V charging voltage now used to charge the battery and to run all the electrical devices on the car. A good lead acid wil measure 2.1V per cell and that will give you 12.6V on a good resting battery. When the Alternator run it will provide 13.8V charging voltage and the moment you switch the head lights on, the more current will try to let the voltage drop and that is sensed by the voltage regulator that will increase the voltage and therefore the current through brushes to the stator slip rings to create a bigger rotating magnetic field on the stator and that will induce a bigger AC current into the field coils of the Alternator, this will be rectified by the diode pack and more current result in more voltage and therefore the expected drop does not happen and stay at 13.8V. Starting is the only valid test for a car battery. If the Voltage on a fully charged battery drop lower than 9V it needs replacing. If the resting voltage of a fully charged battery is lower than 12.6V like 10.5V it means 1 cell is Short circiut. A good Alternator will keep the charging voltage 13.8V if you load the system systematic, starting with 13.8V with engine running, ignition and normal radio draw +-6Amp, add Lights, add interior fan, wait for electric radiator fan to kick in, should stay at 13.8V. Good Alternator. 13.8V indicate that the Alternator can supply all the current used by the electrical system and also keep charging the battery to full capacity. Less voltage will calsify the plates and jeopardize Starting current. New Natrium Sulfide System is the same but charging Voltage must be more than 14V, max 14.4V
Good Answers: 82
09/10/2016 12:25 PM
The cylindrical batteries are 1.5V because they're a single Alkaline cell. They decay from 1.55V when fresh to about 1.1 or 1.0V at end of life. Here's Figure 9.98 from Chapter 9 of our book. BTW, this chapter is available free:
http://artofelectronics.net/wp-content/uploads/2016/02/AoE3_chapter9.pdf
If you take a 9V Alkaline battery apart, you'll see it has six cells packed side-by-side.
http://www.instructables.com/id/Get-Six-15V-Cells-from-One-9V-Battery/
Thanks, Win
In reply to #66
09/10/2016 12:44 PM
The old penlight batteries in the bigger battery case is really old internet bull at least 6 or 8 years old Check it out on Snopes. I can't believe that people still buy into it.
In reply to #67
09/10/2016 12:53 PM
In reply to #67
09/10/2016 12:53 PM
Measure the length of the 6 "cells" and compare it to the length of the 9v case in the picture. Scale shouldn't be an issue as they are next to each other. "They can't fit so this must be bull***t."
In reply to #69
09/10/2016 1:05 PM
Go take one apart.
Then, just go away.
Good Answers: 225
In reply to #69
09/10/2016 5:34 PM
The 9v PP3 battery under discussion here is typically 48.5mm high, 26.5mm wide and 17.5mm deep.
The AAAA (R8D425, LR8D425, 25 etc.) cylindrical cells that are used inside these PP3 batteries are 42.5mm high and 8.3mm in diameter.
Even a dill should be able to figure out that 6 of these will readily fit inside the PP3 case with adequate space for connections.
In reply to #69
09/11/2016 7:24 PM
Check SNOPES for this topic; "mister Ed was a zebra" Jim
In reply to #67
09/10/2016 6:35 PM
You mentioned in a previous post a lantern battery hoax that had 24 cells. If it was truly a standard 6V lantern battery, it would have 4 cells. BUT, there may well be a similarly box-shaped battery that does have 24 cells; it would be a 36 Volt battery. When I was in college, I used batteries that had been the "B" batteries for portable tube radios; they had 200 cylindrical cells held in position by tar, and encased in a cardboard box with the Eveready brand in red ink (I cut several open, to use different numbers of cells for various voltages), and it put out 300 Volts when intact.
Here's a picture I just took of a Duracell Coppertop 9V battery that I just now cut open. Rather than use the normal method of peeling the can off, I used a cutoff wheel in a Dremel tool to remove just enough to see the cells inside, and an Xacto knife to peel away the shrink wrap around the cells, so you can see there is no possibility of faking! You can see the same results of leakage on the top-right cell as you can see on the right terminal.
This is NOT some internet fraud. Go find a couple of old 9V batteries and cut them open yourself!
Good Answers: 22
In reply to #72
09/12/2016 12:25 AM
Oh come on - you did that in Photoshop! Here's proof - I found the original image that you doctored.
This shows how 9V batteries really work:
In reply to #74
09/12/2016 12:35 AM
Good one!
Where do you get hamsters that small? ... And what do they eat? I always wondered what kind of liquid was leaking out of old batteries, now I know!
In reply to #74
09/12/2016 12:23 PM
OK, Let's see what you can do with this view...
Good Answers: 22
#90
In reply to #84
09/13/2016 12:07 AM
Oh no! You idiot!
Don't you know how dangerous it is when you let the horsepower out?
70AARCuda (1); Anonymous Poster (4); Autobroker (13); bigg (1); dkwarner (16); horace40 (1); huntman10 (3); James Stewart (16); JIMRAT (2); JohnDG (2); lrsheldon (1); lyn (14); Oomborrie (4); Out of Box Experience (8); phph001 (1); Rixter (6); RobertOz (7); Solararts (1); SolarEagle (1); spades (3); Torqued (1); Winfield Hill (1)
