Previous in Forum: Export of Solar Power & Import of Grid Power   Next in Forum: Temperature Setting of Panel Air Conditioners
Grid Islanding, Load Shading & Load Shedding
09/30/2016 9:55 AM
Need some write up & experts' opinion on the protection system as below:
1. What is the protection feature to be considered while islanding?
2. How the load shading will be initiated after islanding?
Kindly harp on some salient points which need to be considered?
Enjoy the question till you get the answer
Re: Grid Islanding, Load Shading & Load Shedding
09/30/2016 10:05 AM
This isn't a search engine....
Good Answers: 444
09/30/2016 11:15 AM
We know that you're not an expert, but why don't you try explaining what you think your answers should be, since it's impossible to guess what your exact system configuration is. That way some of the experts here might try and guide you, otherwise you should inform your employer/client that this project is above your pay grade.
ps- there are multiple "protection features" depending upon your goal; and use load "shedding" in your favorite search engine.
Good Answers: 181
09/30/2016 3:45 PM
He’s like an annoying itch that won’t go away.
Good Answers: 11
10/03/2016 5:39 AM
rogerggbr
09/30/2016 6:20 PM
Good Answers: 116
10/01/2016 4:17 PM
  1. Water, food and shelter.
  2. Stand under tree out of sun.
Harping....
We are becoming concerned about your tendency to expect others to do your work.
Explain: meaning of "Grid Islanding","load shading" and "Load Shedding": how you would know they had happened, estimate how quickly they do or must happen, or carry them out.
State what libraries or textbooks you have examined to understand this subject.
As pointed out already, more work by you in describing the problem and your thoughts about it will elicit more fruitful responses.
Register to Reply 6 comments
67model (1); lyn (1); RAMConsult (1); rogerggbr (1); SolarEagle (1); TonyS (1)
