Previous in Forum: Do Planes Really Need a Tail?   Next in Forum: Is...Is Microsoft Actually Good Now?
8 comments
High Def Video Underwater
10/25/2016 9:34 AM
I remember reading about a method of sending Hi-Def video underwater,wirelessly, using a new form of sonar signal generator.
The sonar signal generator used a laser to generate the high frequency signal,which could not be produced by previous transducer technology.
I seem to remember a super-heated bubble generated by a laser beam that generated the pulses.
I cannot seem to locate the article now, so if anyone remembers it or has a link,it will be sincerely appreciated.
Google links only to fish finders,etc,and I cannot find any references to the article I read.
Thanks in advance for all help on this.
Re: High Def Video Underwater
10/25/2016 10:58 AM
10/26/2016 8:22 AM
Not exactly.But a very informative link nonetheless.Thanks!
As I remember it, in the article I read,the laser was used to generate a high frequency sound signal that was impossible with the state of the art piezo-mechanical transducers at that time.
The laser created a cavitation bubble that collapsed,which in turn generated a shock wave in the water.
A single bubble was impossible to generate,so groups of bubbles were sent as a single bit.
This method also made decoding difficult for anyone trying to decode a single bit.It would look like noise to the uninformed.
The bubble collapse emitted a particular frequency dependent on bubble size,external pressure on the liquid transducer, the type of liquid/mixture,the coupling membrane material composition and thickness,and other factors not enumerated in the article.
I do not recall the frequency,but apparently a particular wavelength had been found that was transparent in seawater at that particular frequency.
It was being tested and evaluated for military purposes.
Odd that I can recall so much about it,but cannot recall where I read it,but I know it was approximately 10 years ago.
Sort of like recalling events from your childhood more clearly than what you ate for breakfast yesterday morning.
Technology has probably moved far beyond this stage by now,and the prototypes are probably boat anchors by now.
Thanks to all for the feedback.
10/26/2016 9:28 AM
10/26/2016 10:18 AM
LIB or laser induced breakdown is becoming a wider field, now has many spectroscopic applications for PMI (positive materials identification).
Note that since the pulse is temporally compressed in the water, and somewhat self-focusing, this will lead to a cavitation, laser induced breakdown. It will produce a very sharp acoustic ping with high intensity.
Obviously, sonic imaging relies on very short pulses, to that resolution of return pings has the capability of being resolved to smaller dimensions.
10/25/2016 12:01 PM
At first, I read the title as High Def Video Underwear.
Or did you mean synthetic aperture SONAR?
http://www.krakensonar.com/en/
I think laser diodes are more for high speed communication underwater.
10/25/2016 2:37 PM
Maybe this?
https://www.sciencedaily.com/releases/2009/09/090904165241.htm?trendmd-shared=0
A problem with underwater communication is that bandwidth and range are incompatible: High data rate means short range.
http://helper.ipam.ucla.edu/publications/quant2012/quant2012_10816.pdf
10/25/2016 2:49 PM
Does the optical part of that graph include all wavelengths extending into the NIR?
10/25/2016 4:10 PM
I suspect it's the blue-green band. Water absorbs most electromagnetic radiation except for a narrow window in the blue-green optical region.
https://en.wikipedia.org/wiki/Electromagnetic_absorption_by_water
Register to Reply 8 comments
HiTekRedNek (1); James Stewart (3); Rixter (3); SolarEagle (1)
