I have a box of 96,000uF 10 VDC capacitors and I need to measure their ESR at 120 Hz. None of the LCR or cap meters in my lab are calibrated for ESR due to a technical problem with the procedure (long story, don't ask). The manufacturer uses a meter to measure ESR and may be derived from DF hence the 120 Hz parameter. I turned the web inside out looking for information on how to directly measure ESR and the only 2 methods that provide actual values are DC based or only work on small value caps. With all the giant brains reading this list someone has done this already.
