Previous in Forum: Circuit Breaker OK But Elaborate Trip During Heavy Rain & Thunder   Next in Forum: Correct Delta Connection
PT Connection
11/29/2016 5:50 AM
What type of PT configuration is this?
1. I cannot understand why A-phase of the secondary Delta winding
of PT and B-phase of star winding are grounded.
2. Why Primary and secondary neutral have separate winding?
Re: PT Connection
11/29/2016 7:07 AM
The individuals who drew, reviewed and approved the installation for construction should be in the various boxes in the corner of the drawing. These would be the best people to ask.
Reply Score 1 for Off Topic
Re: PT Connection
11/29/2016 9:05 AM
Re: PT Connection
11/29/2016 10:37 PM
The drawing are not drawn professionally really can see which is primary winding and which is secondary winding
Good Answers: 181
Re: PT Connection
11/30/2016 3:27 AM
The question has already been answered for you on another website.
Good Answers: 116
Re: PT Connection
12/01/2016 12:22 PM
1. PT secondarys are always earthed - as part of keeping xxxkV from LV equipment and you. Capacitance coupling to unearthed secondary from HV primary is enough to be lethal, particularly since current in normal conditions could exceed "let-go" hand potential. Which phase is earthed would be just convention.
2. The neutral has a separate PT. My opinion is that the interconnection of the 4 PT secondaries is a) the same as that of primaries, plus it gives "zero sequence" voltage, "positive & negative sequence" voltage and 3 line voltages to earth separately in LV circuit.
3. the lower secondary of the 0-X0 PT primary may be because the PTs have two secondaries any how; opposite polarity might be required - note obvious cross-over of secondary connection; or maybe diffferent voltage required.
4. As has been commented, the manufacturer or the protection relay drawings and types or maintenance manual may help.
67model (1); PWSlack (1); Simon Wan (1); SolarEagle (1); TonyS (1)
