Previous in Forum: Correct Delta Connection   Next in Forum: Harmonics & Mitigation, Power Factor, Damage from Harmonics and Power Costs
20 comments
Open Loop Poles That Are Not There?
11/30/2016 3:38 PM
I have a simple open loop transfer function of a system. It comes from an example problem in the Ogata Controls books on page 343
Example 6.10
The book tells us we have an open loop transfer function of the following
Obviously there is an unknown variable k in the transfer function
The example then goes on to say that the closed loop transfer function is the following
The CLOSED loop tf has the following characteristic equation.
Ok fine also no surprise if you go out and do the math.
They then take this thing which is the denominator of the closed loop transfer function and say Now divide by the sum of the terms not involving k and you will arrive at the following
So now we can see that they have arranged the denominator of a closed loop TF in the standard form for unity feedback of G/1+G where G is the feedforward TF
Obviously the idea was to get the unknown term of K out of the denominator Here is what i don't get.
They solve the denominator of this new equation i just posted above set equal to zero and then say those are the OPEN loop poles. Aren't these the CLOSED loop poles????
They say the open loop poles are
How is this possible given the fact that if you do the same exact algebraic trick with the actual open loop transfer function you get a different answer.
So going back to step 1
Take the open loop TF
Take the characteristic aka the Open loop poles
S*(s+1)*(s+4)+20*k*s
and do the same thing. Divide by the sum of the terms not involving k and you would get
1 + (20*k*s)/ (S*(s+1)*(s+4)) = 0
Solve the denominator for the roots and get the OPEN LOOP POLES of
S=0,-1 -4
So my question is, how are they getting the open loop poles by solving the denominator of the closed loop transfer function for zero when any given day those would normally be the closed loop poles but yet solving the open loop transfer function denominator for zero does not yield the open loop poles?
I hope this made sense.
Any help greatly appreciated as I'm desperately trying to understand what the book is doing in the example problem.
Pathfinder Tags: Control system help
Re: Open Loop Poles That Are Not There?
11/30/2016 7:14 PM
It's been a long while since I looked at Laplace transforms!
But here goes...
Here is a general form:
Your example has both an inner loop and output loop.
In the inner loop, G1 = 20/((s+1)(s+4)) and H1=k
In the outer loop, G2 = G1/((1+G1H1)) and H2 =1
Open loop poles are where the denominator of Gn is zero, whichever loop you are referring to (set Hn = 0)
Closed loop poles are where the denominator of Gn/(1+GnHn) is zero
https://en.wikipedia.org/wiki/Closed-loop_transfer_function
11/30/2016 9:04 PM
Hi
thanks for the reply
i understand everything you said wholeheartedly
however I'm confused because In there example what you typed and everything I know about controls is violated
hence my confusion
11/30/2016 10:43 PM
Denominators of zero are a big problem no matter what else may be the case.
12/01/2016 1:34 AM
Care to take a stab at it?
12/01/2016 2:07 AM
No. If you don't already know about division by zero, you are hopeless.
12/01/2016 12:18 PM
you are funny
You really don't think i understand what a pole and zero are!
YOU ARE NOT READING THE QUESTION CAREFULLY ENOUGH!!!
Instead your opting to be a jerk and show your inability to read a question
You sir a hopeless.
READ THE QUESTION BEFORE GIVEN A WISE ANSWER!
Let me spell it out for you.
If you have the open loop transfer function ALL BY ITSELF
and you solve the denominator for = 0 you should get the OPEN LOOP POLES!
If you build the closed loop tf aka
g/1+gh
where GH is the "open loop transfer function"
YOU GET A DIFFERENT ANSWER!!!! then just taking the GH that was given initially!
That is the question Mr hopeless
12/01/2016 10:37 AM
*** See my comments ***
Example 6.10
*** So far, so good ***
*** If you divide by s3+5s2+4s+20, and if s=-5 or +/- j2, you are dividing by zero ***
S=0,-1 -4
12/01/2016 12:23 PM
Guys you must read the question correctly!
I know how to find open loop poles! if i didn't i would just quit engineering all together!
That is not the problem!
The problem is there is a discrepancy in the ANSWER!
You must read the entire question!!!
Loop at the open loop transfer function!!
Take the denominator and set it equal to zero!
divide it by the sum of the non k terms to get the k out of the denominator.
then solve that denominator for zero!
YOU GET A DIFFERENT ANSWER THEN IF YOU DO IT IN THE CLOSED LOOP FORM!
How is it possible the STUDENT is the only one that sees the issues here!
Do us all a favor, unless you are going to take the time to really read and understand the issue and work it for yourself then just don't answer.
Im not a moron i know what a pole is. If you guys did the problem for yourself you would find the discrepancy.
If i go ask a 90 year old pain in the ass old fart professor about this he doesn't know why either.
What the hell was i thinking assuming the engineering community would offer any help what so ever
12/01/2016 3:22 PM
Wannabe, you said "If i go ask a 90 year old pain in the ass old fart professor about this he doesn't know why either."
Do you get something like this from the Old Fart?
12/01/2016 4:38 PM
o man that was so funny
You have successfully demonstrated 2 things
One you can't read, other wise you would understand the question.
Two, you can't answer the question because you don't know anything about controls or what I'm asking.
And the reply from my professor was " I DONT KNOW WHAT THEY ARE DOING IN THE BOOK" because he doesn't have a clue just like you guys.
This is seriously the ieee forum? wow i hope the fate of the universe is not in your hands
12/01/2016 4:53 PM
I hope you are good at figuring things out on your own because working with others and inspiring others to help you don't seem to be on your list of strengths.
I don't know if you have done this internet thing before but when you ask a question you normally get 20% of the responses that you classify has trying to be helpful, 20% that are of a negative nature and 60% that you just don't know how to classify. If you want to benefit from the first 20% you can't be blowing up on the other 80%.
Of the 3 responders Rixter seems to have put quite a bit of HIS time and HIS effort into trying to help you. That is 33% helpful. I'd say you had a good thing going and blew it.
Another way to look at it. We are not in your class with you. You are not paying us to tutor you. I think you got far more than you paid for. I think short polite responses or no responses to the less helpful responses might have been a better choice.
12/01/2016 6:34 PM
O right
the old turn the other cheek bs
i forgot I'm not allowed to defend myself against internet bullies that just spout off with nonsense replies and when you do you get ridiculed
good old internet
and thanks I am good at figuring stuff out in my own. When idiots reply with idiotic answers I should expect nothing less
no surprise
I never forced anyone to offer help but if your going to offer help at least make sure you have a fregin clue what your talking about which none of you do
comical
I found the answer I was looking or and everyone of you missed it
getting the open loop poles of a fictitious system is a method of plotting a loci when the fictitious system and the real system share closed loop poles
buy only one person rixter even attempted to understand what was going on
12/01/2016 7:19 PM
Illiterate drivel; not worth bothering to count the mistakes.
12/01/2016 7:40 PM
awwww but you just can't help but to reply can you.....
classic a88 holes on a forum
no surprise
12/02/2016 7:30 AM
We are grateful that you are taking such a strong stand against internet bullies.
Do others refer to you as "WannaBe" or is that just the way you are identified here?
12/02/2016 2:26 PM
I willingly call myself a wannabe because I wanna do controls but in reality I don't know jack because I have had to teach myself everything I do know with you tube videos because the tenure system at universities is single handedly responsible for over priced educations and graduating "engineers" that don't know squat.
When the professor has to ask the class what the run button in matlab does there is something wrong.
So I'm definitely a wannabe, but I'm trying to make something of myself so when I'm don't understand what is going on I'm searching out the answer.
12/02/2016 11:14 AM
There are several comments within this thread that seem a worthy exception to my general rule of not voting anything OT.
Wannabe, you said "This is seriously the ieee forum? wow i hope the fate of the universe is not in your hands" No, as disturbing as this thought is, the fate of the universe is in your capable hands.
12/02/2016 2:30 PM
if its in my hands you should be smiling that a student who graduates this semester btw is in search of answers for something he does not understand
The rest of my class couldn't care less as long as they pass. I refuse to give up on this.
I spoke to another person today who teaches controls and he said the example is trying to demonstrate finding the closed loop poles of one system by finding the open lop poles of some "fictitious" system and exploiting some property that the systems have in common
Something about the real and fictitious system share closed loop poles but not open loop ?????
Which still makes no sense but atleast verified my point that something is a miss here.
They are not simply finding the open loop poles of the system. There is still something going on with this problem
12/02/2016 2:40 PM
Just in case you are wondering...
The original posting and postings 17 & 18 seem to be from someone who would fit in here pretty well. If the guy that wrote 7, 8, 10, 12 & 14 were to chill out I suspect most of us would welcome you.
12/02/2016 7:26 PM
Again the point I'm trying to make is the following
In step 1 they say the open loop transfer function is
Then after they do the algebraic manipulation to get the closed loop Tf in the form
g/1+gh
They say GH "aka the open loop transfer function"
is
Note the picture above is the CLOSED LOOP IN THE FORM
g/1+g*H
Therfore this G*H must equal the G*H from step one
and it does not
I wrote a matlab script to prove my point.
Pick any value of S and K plug them in and compare the answers.
The values are different.
THIS is the problem
syms k s
eq1 = 20/(s*(s+1)*(s+4)+20*k*s);
eq2 = 20*k*s/(s*(s+1)*(s+4)+20);
K = linspace(.1 ,20,100);
S = linspace(.1,20,100);
for x = 1:100
eq1C = subs(eq1,k,K(x))
eq2C = subs(eq2,k,K(x))
eq1C = subs(eq1C,s,S(x))
eq2C = subs(eq2C,s,S(x))
if eq1C == eq2C
disp('they are the same')
break
else disp('they are not the same')
end
end
Register to Reply 20 comments
Anonymous Poster (3); Doorman (2); Rixter (2); Tornado (3); wannabeControlguy (10)
