To recharge a residential 3 tons central a/c unit. What is the typical amount of refrigerant that one need to put in thru the low pressure side? How can I check if the system needed refrigerant or too much refrigerant causing it not running (Cold) efficiently ? If the system depends on the length of the copper line and the cooling temperature that desired ? Any typical amount that someone can suggest or recommend ? Does the system have an typical optimum high pressure level (psi) and low pressure level (psi) ? Thanks for the comment in advance !!
