Previous in Forum: Tracking a Dead Circuit   Next in Forum: How to Control Lights?
Old LCD Display Around 4'' Replacement
12/25/2016 10:29 AM
Hello,
I have an old LCD display around 4'' size.
It is using Segment/COMM drivers ICS (OKI MSM5299B and MSM 5298A)
it is using two connectors (18 pins) for segment driver:
one connector for each half of the screen and a connector the common driver.
each half is controlled by 3 OKI MSM5299B.
LCD is broken and need to replace it.
Is there an LCD that accept inputs for OK MSM5299/5298 ?
Can you help with that.
Re: old LCD display around 4'' replacement
12/25/2016 10:44 AM
"an old LCD display around 4'' size." leaves many options.
If it has to fit into a case, more precise dimensions are required.
Maybe even a picture of both front and back, or at the very least a part number.
12/25/2016 11:00 AM
Unfortunately, no part number but I know that it is dot matrix LCD that is driven by MSM5299B 80-Dot segment driver and MSM5298A 68-Dot Common Driver.
12/25/2016 11:08 AM
12/25/2016 12:13 PM
12/25/2016 12:44 PM
Green1969 (1); lyn (2); SolarEagle (2)
