Previous in Forum: Is it Possible to Make a Button Head Machine Screw a Certain Size/Gram Weight?   Next in Forum: Electrically Powered Aircraft - Again
15 comments
SpaceX Plans to Fly Again
01/02/2017 1:07 PM
..."In its statement, SpaceX said it traced the cause to a pressure vessel in the second-stage liquid oxygen tank. The tank buckled, the company said, and supercooled liquid oxygen pooled in the lining. The fuel was ignited by breaking fibers or friction.
The company said that in the short term, it plans to change the way it loads fuel. Eventually, it plans to change the design of the pressure vessels to prevent buckling."...
Maybe they could layer in some graphene sheets....?
http://www.parabolicarc.com/2014/04/05/composite-tank/
https://www.washingtonpost.com/news/the-switch/wp/2017/01/02/elon-musks-spacex-says-it-has-found-cause-of-rocket-explosion-and-plans-to-fly-again-sunday/?utm_term=.3e3c53282452
http://www.spaceflightinsider.com/organizations/space-exploration-technologies/spacex-narrows-cause-falcon-9-explosion-targets-mid-december-launch/
http://www.laserndt.com/technology/ndtapplications/copvtanks.htm
Re: SpaceX plans to fly again
01/02/2017 1:20 PM
01/02/2017 2:34 PM
Look for a repeat
01/03/2017 1:39 AM
Something to watch again and again, right Fred?
Maybe they start building an electrically powered rockets if its possible.
Reply Score 1 for Off Topic
01/03/2017 8:13 AM
1. Will the 13 Amp extension lead comply with the IEEE/IEC standards?
2. And if so, who's job is it to wind it up again?
3. If battery powered, do they get a pink rabbit with each set of batteries purchased?
4. Why not just reverse gravity and let it float up, give it a little nudge to get started.
Good Answers: 445
01/02/2017 3:48 PM
Maybe they shouldn't rely on design information from posters on CR4!!!
01/02/2017 4:31 PM
Why not? I haven't blown anything up ....and in case I haven't said it lately, I can fix anything......
01/02/2017 5:25 PM
"Maybe they could layer in some graphene sheets....?"
I dunno, it's strong stuff but I'd be leery of using graphene in a tank designed to hold LOX, even if the layers were buried inside laminations.
Graphene is pretty chemically reactive overall but especially along its edges. Extremely reactive. A crack or tear could expose those edges to pure oxygen and no telling but the thing could catch fire and we'd get a repeat performance.
01/02/2017 8:19 PM
Perhaps they could stabilize the graphene....
reference
01/02/2017 11:46 PM
Makes one wonder, though, after the stabilisation is it still graphene with all of graphene's properties of strength and so forth? I don't know.
Given that this is a LOX tank, especially, I would not be inclined to make it using carbon-based materials. Spun fibreglass, maybe; depends on how it responds to cryogenic temps. But if the stuff burns, I wouldn't use it anywhere near pure oxygen. That's asking for trouble.
01/03/2017 12:07 AM
Well the carbon fiber wound tanks are much stronger at the low temperatures required....I would also think the carbon fiber tank could be grounded easier or more effectively than fiberglass....there is a problem with microcracking with all composites I think due to the rigidity of the structure at such low temps...so I think that is the main problem... adding some flexibility is a challenge....a self-healing fiber maybe...
http://scholarworks.uno.edu/cgi/viewcontent.cgi?article=1169&context=td
01/03/2017 12:45 AM
Kevlar and Twaron are notably strong at cryogenic temps.
Re: SpaceX Plans to Fly Again
01/02/2017 11:04 PM
"...The tank buckled..."
? Maybe the original fueling procedure had a vacuum drawn on the tank prior to filling with LOX?
01/03/2017 12:15 PM
Or possibly the LOX tank pressure exceeded the helium tank pressure. If these tanks are designed for internal pressure (and not much at that), what would be the pressure differential limit externally?
01/03/2017 11:26 PM
I can't see what the big deal is, every manufacturing operation has an acceptable degree of waste, why else would anyone buy Brooms and dustpans.
01/04/2017 2:01 AM
"...why else..."
The Broom is the preferred means of personal transportation for some....their husbands are typically relegated to following on the dustpan.
Reply to Forum Thread 15 comments
Andrew Westman (2); Fredski (1); gutmonarch (1); IQ (1); RAMConsult (1); SolarEagle (5); tonyhemet (1); truth is not a compromise (3)
