Previous in Forum: ovality control in y- ring to skirt joint, pressure vessel manufacturing   Next in Forum: Measuring paint thickness on hot rolled steel
Leadframe sizes
08/12/2007 11:07 PM
Hi, anyone here in the semiconductor manufacturing/packaging industry? Does anyone know what the largest leadframe size there is right now, or coming up in the near future? I keep hearing about this "High Density Leadframe" with a width of up to 80mm, but not sure if this is just day dreaming by some packaging engineers or really something which is becoming a reality. Thanks!
Pathfinder Tags: leadframe
Good Answers: 94
Re: Leadframe sizes
08/14/2007 4:32 AM
Mintech make semiconductor packages. I have a catalogue which is a few years old & the maximum package size I can see is 81.28 x 86.36mm with 124 pins.
Re: Leadframe sizes
08/14/2007 8:07 AM
Lead frames are manufactured by either stamping or chemical etching. Stamping is lower cost per frame, however, tooling is expensive. Etching is more costly per frame but tooling is low cost. If you can imagine a planar leadframe of any size, it can be etched.
Re: Leadframe sizes
08/17/2007 5:24 AM
You're probably talking about Matrix Frame where there is multiple row and column. I heard one semicon company is having 72mm width for QFP1010-52Pin (4 x 10 matrix) & QFP1414-100Pin (7x8). It's a way to reduce frame & material e.g resin cost as well as m/c thruput up. ANyone else have more info ?
Rgds
Re: Leadframe sizes
08/20/2007 10:50 PM
Hi All! Thanks for the inputs. I am indeed taking about matrix leadframes.
Register to Reply 4 comments
Anonymous Poster (2); Nigh (1); Solrac (1)
