Anonymous Coward writes:
Hi everybody,
I'm Hairudin and I perform leak testing and hydrostatis testing for valves. Recently a client requested that I test their valves for leakage. The problems is:
1). The process line doesn't have any isolation valves to by-pass the process medium.
2). There's no flow indicator or transmitters to detect the process variables of the process medium.
3). The process line doesn't have a common drain valves that can be opened while the process is running.
4). Packing at the by-pass valves are passing.
My client requested that I check the leak rate - whether it is within the specification criteria. What is the best method for me to check the leak??
Thank you and best regards:
Hairudin
