I have been studying the photos of the I-35 Bridge collapse and have noticed many of the steel structure failures have occurred at the points where the steel beams were joined by riveted splice plates. I was under the impression that a properly riveted splice (using correct rivet patterns) was stronger than the parent material. I am seeing extensive brown rust at the points of separation. I am an aircraft mechanic and we frequently splice aluminum structures by riveting. My electrical engineering sheepskin doesn't give me much help in this case. Could some of you mechanical engineers comment on this.
Snakers
