Previous in Forum: Light Breaking Speed of Light?   Next in Forum: EMAT Technology
MIG Welding
08/16/2007 2:04 AM
HI. I am trying to weld 0.8mm aluminised steel using the synergic mig process on a semi auto welder. The joint configuration is a butt joint which may have gap of up to 1mm. I am using normal copper coated mild steel wire. Up to yet nearly every one i have welded has blown a hole. is there any wire or process available that is more forgiving ?.
Re: MIG Welding
08/17/2007 1:39 AM
We recently had a project using 16 gauge aluminized steel and found it was better to grind off the aluminizing and drop our wire size to .025 in. The thickness of the metal you are welding is pretty thin. Can you back the material with copper prior to welding? Wire fed TIG might be a solution
Re: MIG Welding
08/17/2007 2:20 AM
TRY TIG AC Autogenous - means no rod filler .
Let steel melt-and join itself and Al coating to melt and join Al toAl .
You may finally have to do in 2 passes:
#1 MIG WITH MS WIRE 0.6MM auto feed.
#2 TIG AC with Al wire 0.6mm hand feed.
Good Answers: 94
Re: MIG Welding
08/17/2007 5:06 AM
We regularly TIG weld steel from 1mm down to 0.1mm, mostly around 0.5-0.7mm & have to get vacuum tight joints. The joints are normally circular & welded using a motor driven turntable and fixed torch. We don't use any filler, just use as light a weld as possible but any gap in the joint will cause it to blow through.
Re: MIG Welding
08/17/2007 8:09 AM
control current / voltage input
Engg Design, 150 hp/1000 cc, 1600 hp/2400 cc F1; 600 kph MonoRail,Ferry,VLCC
Re: MIG Welding
08/18/2007 7:28 PM
Has anyone tried pulsed mig, I know pulsed tig would be easy for this but for a semi-auto mode?
Re: MIG Welding
09/11/2007 3:53 AM
I understand it is difficult to weld a thin material. For a 0.8mm steel i suggest to use welding current (wire speed) around 63 ipm. Then adjust your voltage to get the desire 'weld bead'. You must use 0.8mm wire diameter to weld thin material.
You may also try to use Accu Pulse Welding Method if it is supported by your Welding set. Please contact your welding set supplier to get help on proper welding parameter if using accu pulse.
Copper Backing Bar or Plate which is place at the back of the welding point will help to absorb heat and thus solve welding hole issue. But copper backing bar/plate usage is limited to part and/or jig design.
Hope this would solve your problem.
Register to Reply 6 comments
Anonymous Poster (1); appan (1); MUKULMAHANT (1); Nigh (1); Nishar (1); possien (1)
